Problem - Ford Truck Enthusiasts Forums
Problem
Old 03-13-2007, 08:43 PM
TLyttle TLyttle is offline
TLyttle is starting off with a positive reputation.
Problem
I learned decades ago what the answer to this is, now I forget.
What busts up the rings? I used to think it was poor timing, but this thing was timed correctly. Lousy fuel? Overheat? Or just plain old age?
I need hints...
Old 03-14-2007, 08:32 AM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Probably the number one breaker of rings is detonation (pinging). Excessive/frequent overheating can weaken the rings, especially old high-mileage rings which can lead to breakage. Lousy fuel? Well yes...if it causes detonation. Poor timing can cause detonation, but you can still get it with the timing spot on in many cases, depending on load.
Old 03-14-2007, 08:06 PM
Thanks Dan, confirms my scenario. This is a high-mileage engine, and ran like junk, which led to the teardown. Ah, well, limber up the wallet, here we go again...
77 400 timing lifted77f250 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 04-12-2005 05:42 AM
timing mud bug1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 08-16-2004 08:56 PM
Propane timing ? akita 1987 - 1996 F150 & Larger F-Series Trucks 1 03-29-2004 08:55 PM
total timing fordeverpower FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 12-05-2003 08:13 PM
1990 f150 300six timing? dandyferg 1987 - 1996 F150 & Larger F-Series Trucks 2 11-25-2003 07:49 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
