Custom Stereo Installation - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-13-2007, 09:34 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
I have a fairly new Cobra 29, (I think thats the model....it's in the workshop right now). And I have a kenwood, (standard DIN height), installed in the dash with the standard install kit giving you a pocket below the head unit. What I was looking for, and I didn't really look too hard, but is some sort of kit that would allow me to install the stereo about 1/4 inch higher,pretty much getting rid of the kit's plastic trim above it and it would make enough room for the cb below it. The cb's speaker is on the face so I don't have to worry about an external speaker along with the mic jack. Or...The other option I was thinking of, is instructions or a kit to install it into the pocket above the driver's right knee in the lower dash. I would like to install this flush mount with the dash instead of under the dash...mainly for the clean looks. Has anyone on here done this or know where I can get the information for doing this? I am hoping for a dash kit to install it in the double din space with the head unit so I can save what is in there now in case I ever want to switch it back and not have to modify the dash panel.
Thanks all!
Old 03-14-2007, 12:38 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I have seen it done in a dodge and it looks ugly. That was a much bigger radio though. The smaller radios maynot look as bad.
All of the kits I have seen but a perimeter around the radio. So I would look at either modifing the kit you have or putting in the pocket. For the pocket install, remove that lower portion of the dash, cut the bottom of the pocket open enough to stick the bracket in it and bolt the bracket down. You shouldn't see much of the cuts, and if you do, foam or electrical tape will cover it up.
Old 03-14-2007, 01:03 PM
Dragrazor's Avatar
Dragrazor Dragrazor is offline
Dragrazor is starting off with a positive reputation.
anyone have pics
Old 03-14-2007, 08:33 PM
BillyBob69's Avatar
I did a post in another thread and someone found me this link....
http://www.bestkits.com/ViewImage.as...i/BKFMK552.jpg
I'll post pics when I get her done.
Old 03-18-2007, 09:52 PM
Dragrazor's Avatar
pics???????????
Old 03-18-2007, 09:59 PM
BillyBob69's Avatar
LOL I'm still waiting for the part to come in. I will be sure to post pics when I get the install done. But nothing too quick....I also have horses to work with. I don't always get the time I want to play with the truck.
Old 03-18-2007, 10:04 PM
Dragrazor's Avatar
ok cool!!!!!!!
Old 03-31-2007, 03:32 PM
BillyBob69's Avatar
OK It is done. Took about 4 hours since I had to trim the top and bottom flange in the dash for the units to fit. But once I did that...fit like a glove. Had to also trim a little on the face piece around the units since the CB was a little wider than the stereo. Anyway...here it is done and complete. (And yes, that's my I=Pod in the pocket. That plays through the stereo too with an adapter from Crutchfield.com...No FM Modulation)
I could of had it out just a little further, but decided to plant it all the way in. Otherwise it would of been flush with the dash face.
Old 04-01-2007, 03:52 AM
04F-250 stroked 04F-250 stroked is offline
04F-250 stroked is starting off with a positive reputation.
prettyfriggen' sharp looking!!!
Old 04-01-2007, 12:47 PM
dsldandually's Avatar
dsldandually dsldandually is offline
dsldandually is starting off with a positive reputation.
Very Nice, looks great
Old 04-01-2007, 01:58 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Looks like it turned out pretty good BillyBob69.
Old 04-01-2007, 02:06 PM
Fishsimion's Avatar
Fishsimion Fishsimion is offline
Fishsimion is starting off with a positive reputation.
BillyBob69 , thats one really sharp looking install.. Very Professional..
Old 04-01-2007, 02:07 PM
Dragrazor's Avatar
niiiiiice!!!!!!!!!!!!!!!!
Old 04-01-2007, 03:20 PM
BillyBob69's Avatar
I tell ya what though....Couldn't of done it without my Dremel. One of the best tools I have ever bought!.
Old 04-07-2007, 04:29 AM
Flatdeck's Avatar
Flatdeck Flatdeck is offline
Flatdeck is gaining momentum as a positive member of FTE.Flatdeck is gaining momentum as a positive member of FTE.
Thanks for posting the pics; awesome job on the install!
I eventually want to mount a DIN-sized Motorola Spectra VHF radio below a new stereo, but to date have not removed the stock stereo (cassette!!) so I didn't know if I had enough depth. I believe the Spectra has a depth similar to your Cobra so I think I'm good.
Double Din Trumps the Single Din Whitey Ford 1999 - 2003 7.3L Power Stroke Diesel 3 11-11-2016 07:24 AM
Modify dash to accept a deeper head unit? Sidecutter 1999 - 2003 7.3L Power Stroke Diesel 11 07-07-2015 10:05 PM
Single Din Stereo Install in 75 F100? KG Excursion 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-24-2015 12:21 PM
How to properly install 99-04 double din head unit xmontex4 1999 to 2016 Super Duty 7 03-15-2012 10:54 PM
Radio Upgrades cb_murray 1967 - 1972 F-100 & Larger F-Series Trucks 13 07-10-2006 01:05 PM
Tags
03, cab, crew, custom, enthusiasts, expedition, f150, f250, ford, installation, installs, motorola, radio, spectra, stereo, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
