ats and actuator rod
There's a little E-clip that keeps the wastegate actuator rod attached to the wastegate valve's arm that extends up out of the turbine. A little 90* pick will help in removing the clip... you can slip it onto the backside and pull. I didn't have a nice pick at the time I installed mine, so I bent a small to an angle and gripped it with a small pair of vice grips, and used that as my pick. The clip will probably go flying, so good luck with it... best to replace it with a new Napa circular linkage clip. Check the Common Mods thread for a post by me that has the part number if you'd like it... the new clip you can slip on and off quite easily.
rusty70f100
12-04-2005 05:36 AM
grandjunktion
11-29-2004 02:52 PM
