I threw it on my sister's laptop while I was laying on the couch playing with after I got my wisdom teeth pulled. I don't think she leaves it on all the time though, so they may just end up timing out. We will see..
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460 and things
-2003 F350 Supercab shortbed FX4 6.0 PSD
Every bit of this team getting in the top 1000 is due to you all and you should be proud.
you all are my heros and part of a helpfull aspect of my loss and helping me get through it.
not everyone can fold a WU/day. if you fold 1 a month.... you've carried water that most can't or won't.
my eternal gratitude and prayers for your help
One of my computers runs the SMP client fine. First WU in on that, up to 27059 points, woohoo!
Problem is, the other computer with the Opteron 1218 processor doesn't like the SMP client at all. It always gets an error FFFFFFFF after about 10 seconds and deletes the work unit, and downloads a new one, with the same results.
Any ideas?
Edit: I think I know what it is, I probably dont have the .NET Framework 2.0 installed on that computer. Let me go try that...
captain p4, i noticed that you have 2 names. you can run the same name on all of the pcs if you want to. unless you want your stats split. i have this on 8 pcs and all on the same name
I am so proud of mine, its been cranking out 5000frame WUs about every two days.....pretty impressive for a pre-packaged laptop i thought.....Glad to see we're under 1000! Keep it up team!
__________________
Nick
1987 F-150 4X4 Standard Cab Long Box 351W EFI, ZF 5speed, 3.55s
