477 gas engine questions
Old 03-13-2007, 09:52 AM
fordpull's Avatar
fordpull
fordpull is offline
I have a 477 gas engine IT backfires through valve cover 2 and4 cy have no builds upcompression is the intake or exhaust valves bent or sticking or cylinder damage compression builds up and blows the valve cover cap off any suggestions greatly app thanks
Old 03-13-2007, 06:00 PM
HOTWRENCH's Avatar
HOTWRENCH
HOTWRENCH is offline
Talking
Sounds like you have a hole in a piston .
Good Luck ----------------Hotwrench
Old 03-24-2007, 01:49 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
You're going to have to pull the head at a minimum. Maybe that hole in the piston is brought on by a dropped valve.
Old 08-31-2007, 03:09 AM
mchne33's Avatar
mchne33
mchne33 is offline
blown pistons common to 477s?
hey are the 477 engines known to blow pistons? unrelated but important question: i have no crank for mine, is there any other cranks that share common main bearing spacings?
Old 08-31-2007, 03:10 AM
mchne33's Avatar
mchne33
mchne33 is offline
are 477s prone to blowing pistons?
Old 08-31-2007, 03:14 AM
mchne33's Avatar
mchne33
mchne33 is offline
hi fordpull -could it be really worn out/cracked valve guides?
Old 09-01-2007, 08:23 PM
85e150's Avatar
85e150
With an engine this old it could be anything. One thing it really is though is a teardown job. Until you pull it apart, it's all guesswork.
If you are hoping to pour a can of Motor Honey or something into it, you are dreaming. Get your tools or checkbook out.
Nolan Harris
401, 477, & 534 SD Engines
29
09-21-2023 09:22 PM
ms_michelle
50
07-22-2019 08:06 PM
Jim534
09-01-2017 07:16 PM
swglanville
10-23-2015 03:52 PM
mrautocar
04-05-2007 07:29 AM
Quick Reply: 477 gas engine questions
