Turn Signal for F-150 Won't Reset
Craig,
I haven't done this myself, but here goes: 1)Disconnect Battery Ground cable.
2) Remove ignition switch lock cylinder.
3) Twist the Tilt wheel Handle and remove
4) Move Gear Selector to lowest position. Release 4 Clips and remove Steering column opening cover.
5) Remove upper and lower Steering Column Shrouds. (three screws on the bottom)
6)Remove Multifunction Switch (Turn signal stalk and switch) There are two screws and one electrical connector.
Good Luck,
Bill
Good Luck,
Bill
