94 Supercab bucket seats in 92 F-150 regular cab
Guys provided that I have the base and everything else that came with the supercab pickup will the supercab bucket seats bolt in with a few holes drilled out and some bracing? My truck currently has the bench seat and found some awesome supercab seats, just don't want to waste my hard earned money that's all...
This is why I ask about the supercab seats...
Originally Posted by jwtaylor
you can use any seat you want however they will not just bolt into your truck. The mount or frame under the buckets is designed differently than your bench and the floors on the xcab and bronco are actually different. So they are not a bolt in deal, yet if you get creative you could put them in there. Good luck
I'd do lots of measuring to be sure they won't be too wide ..floor to top of seats.......front to back......"etc"....Compare them to the bench measurements.......
and from where the holes are for the bench base mounting.
It would seem to me they would be a good fit........but one of the earler posts on this warned about later model seats being somewhat too big. Hopefully these aren't too "later model".
Based on the info before......bases probly just need the inner holes drilled if they measure up ok.
by the way.....I think you can buy 1/4" plate at the hardware and cut it to make braces for the bolts going through the floor.
Good Luck
PS.....don't forget the seat belts and hardware....and let me know how it works out so I can decide if I want to do it. My bench needs recovered and I'm getting estimates....so I'll compare that to swap costs.
Good Luck
Binkowski
06-19-2016 06:23 PM
psquare7575
06-28-2011 10:50 PM
