Max gross weight on F2, F3, F4 VIN Plate
I have the truck and title but the VIN plate was removed. I searched for a reproduction but couldn't find one. Does anyone know where they can be found?
I did find a trophy shop that can make one but I need a little information.. What is the 'max gross weight' lbs value that appear on an F2, F3, F4 VIN? I.e.
F1 4700 LBS.
F2
F3
F4
F5 14000 LBS.
F6 16000 LBS.
Thanks for the help. frank
F1 4700 LBS.
F2
F3
F4
F5 14000 LBS.
F6 16000 LBS.
For original type of tags you can try this place:
http://www.datatags.com/
I have never bought from them but I have referred a few people and they all were happy with them.
51dueller thank you for the numbers. I have a F2 chassis with 5 lug 16 inch wheels and an F4 chassis with 8 lug 17 inch wheels. I like how the 17 inch look in the larger wheel openings. Did the F3 come with 17 inch wheels?
bobj49f2 thank you for the link. I sent them an email requesting information. If the price is right I'll give them a try. That is as soon as I decide if it is F2, F3, or F4.
Yeah I don't have any pics of it. They are these:
http://cgi.ebay.com/ebaymotors/ws/eB...m=140074065321
Only thing I had to do was put some bump stops on the pitman arm, I am running
265/70/17's on them and they touched at full turn. Mainly I just waned to get
out of the split rims and this rims could handle the tires I run on my F150 so I
went with them, when I get new tires on the F150 the '51 gets the old ones.
I will try and get some pics tomorrow I am very pleased with how it looks. They
are a bit shorter than the stock tires that were on the truck but quite a bit wider.
I had these plates made at a local trophy shop. He made both for less than $20. He can make F1-F8 1948-52 (would need to change the LBS and series number). The smaller tag for inside hood is good but not as crisp. My fault, I didn't provide a good pic for that.
Award Trophy CO
11 South Lemon Avenue, Titusville, FL 32796
(321) 269-7584
awardtrophy@yahoo.com
Anyone know where to find the brass rivets?
Award Trophy CO
(321) 269-7584
Frank,
Did you have to supply the trophy shop the blank plates to inscribe? I assume he didn't have them in stock. Did he stampor engrave them?They look very nice and not a bad price.
BTW, all of the trucks I have had had steel rivets holding these tags in. Nothing special, just spiral hammer rivets.
