5.4 motor issues in Lincoln Blackwood
Old 06-15-2009, 09:50 AM
donarmstrong58's Avatar
donarmstrong58
donarmstrong58 is offline
I am having trouble isolating the problem with this motor, I was running down the interstate got on it a little bit and she stalled. I changed all the coil packs and placed new plugs. Which was long overdue; based on the code reading random misfire cylinders, the cats got hot so i replaced them on Saturday. Still nothing. Cleared codes and now truck starts better runs like its missing and the cats on the passenger side get hot quick , so I shut her down....but no codes came up...talked to Ford and they indicated a EGR problem would cause no computer codes...........looking for an answer .....can anyone help.....??
Old 06-15-2009, 01:05 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
The actual codes could help.
Old 06-16-2009, 07:59 AM
torkum's Avatar
torkum
torkum is offline
Start by changing the fuel filter.
Old 08-04-2014, 05:51 PM
bobalew's Avatar
bobalew
bobalew is offline
Bad Bank fire codes? One bad Cyl, or Cyl misfire?
Look at the top of your Air plenum where the EGR valve & Vacuum advance valve connects to the Intake manifold, Right at the top, Under the windshield wipers. Ther's a Right angle rubber connector boot that attaches directly to that vacuum system. There's your leak! Find a silicone rubber Spark plug boot & replace it with that. Trust me, it's weird, but it fits. Otherwise, get few varied diameters of Hoses & hose clamps & replace it with that. This error drove me nuts until it flat out failed. The Alcohol from your windshield washing fluid, deteriorates the rubber on this part, creating a slowly increasing vacuum leak. and Varous BS error codes. This miay also explain the extra oxygen in yopur exhaust, causing calalytic converter overheating. ( SDo that what that HOT smell was...). Any way sorry to let you know tyou spent wat y too much money on fixing it, My fix cost me $8.57 at the local NAPA parts store, & would have been free, if I'd have thought of the spark plug boot fix...
REgards, Bobalew
makingaZJ
07-20-2021 08:43 PM
tjc transport
6.2L V8
03-06-2017 06:49 PM
Bueller
1999 to 2016 Super Duty
03-07-2016 07:50 PM
Fairlane62
1997 - 2003 F150
04-03-2007 11:35 PM
WALJON
10-23-2004 09:11 AM
Quick Reply: 5.4 motor issues in Lincoln Blackwood
