anti theft pats trouble codes - Ford Truck Enthusiasts Forums
Old 03-12-2007, 02:16 PM
patho44 patho44 is offline
patho44 is starting off with a positive reputation.
99 exlpr 4 L sohc. my anti theft light is blinking rapidly. it appears to be blinking out the number 15 or the number 51. where can i find these codes ..i dont see them in the chilton
Old 03-13-2007, 01:13 AM
<TABLE cellSpacing=0 borderColorDark=#000000 cellPadding=0 borderColorLight=#000000 border=1><TBODY><TR><TD vAlign=top width=395>The engine does not start and LED remains off. <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->1. Check PATS system fuses 2. If alarm is fitted check if LED functions for alarm: if not check cigar lighter fuse (also used for LED)
3. If not go to main dealer <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->Engine does not start: LED flashes rapidly <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Leave ignition on until the LED starts to flash a 2 digit code: (sequence- pause-sequence) Check the following codes: <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->Code flashes: <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme--><!--mstheme--></TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:3 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Key code not received. Is key screened by other keys or objects? Try different key: if okay then first key is faulty. If not go to main dealer <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:4 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Partial code only received. Try again. If not okay use different key. If not go to main dealer <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:5 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Key not programmed into PATS. Program key as above using master <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:6 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Faulty link between PATS module and EECV Go to main dealer <!--mstheme-->
</TD></TR></TBODY></TABLE>
Old 03-13-2007, 05:24 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Well thats what I call a GOOD answer.
Patho44, just curious but did you find that in the factory emmisions manual, or the factory shop manual?
I know that for my 87 Ranger the pinpoint tests tests for EEC-4 codes are only in the emmisions manual & I wish I could find one for my 87.
Old 03-14-2007, 12:01 PM
Thanks....i found this on scorpio car alarm site. I just searched the web for ford pats anti theft codes, and sifted through the sites until i came upon this.
Old 03-14-2007, 12:06 PM
I bought this vehicle at auction and only got one key....i finally tracked down the previous owner and got two more keys for the truck. i tried the additional keys but the theft light still blinks rapidly with no start. do i need to take to the dealer to have the pats system reset? I tried discont. and reconnect battery power, but did not help.
Old 03-14-2007, 02:16 PM
If you buy the Ford "electrical & vacuum troubleshooting manual." for a 99 Explorer you will probably be surprised by how easy it is to fix most of the electrical problems on your Ex.
But it looks like your only option for this problem is the-OUCH-dealer.
I dont think theres any easy way to wire around the electronic PATS garbage.
Old 03-15-2007, 10:30 PM
rds4ou rds4ou is offline
rds4ou is starting off with a positive reputation.
Check to see if there are any dtc's present
Old 03-16-2007, 09:21 AM
no dtc's but the battery was dead and it has not run since i bought it.
Anti Theft light Mark Tabor-Paschal 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 3 02-19-2017 05:16 PM
anti theft code olyellow Ranger & B-Series 1 08-26-2015 07:50 PM
Red anti-theft dash light not blinking vicwill Excursion - King of SUVs 5 06-10-2009 06:15 AM
pats anti theft no start patho44 Explorer, Sport Trac, Mountaineer & Aviator 8 09-19-2008 09:55 AM
Anti Theft Dashboard Light TKAT79 1997 - 2003 F150 5 04-15-2006 02:05 PM
Tags
16, anti, code, codes, diagnostic, eecv, f150, faulty, flashes, ford, link, module, passive, pats, problem, reset, system, theft, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
