Air in the cooling system? - Ford Truck Enthusiasts Forums
Old 07-15-2002, 10:45 AM
TheGreep TheGreep is offline
TheGreep is starting off with a positive reputation.
Old 07-16-2002, 11:26 AM
LilTony LilTony is offline
LilTony is starting off with a positive reputation.
94 Ford Bronco - When I start my Bronco in the morning (or whenever it's cold), I can hear water flowing behind the dash board on the passenger side where the heater core is (I think). I've checked for visible leaks and haven't found any. I've called a couple of dealerships and they both told me it sounds like air in the cooling system. Has anyone experienced this? If so, do you know how to remedy this pronblem? Thanks!
Old 07-16-2002, 09:39 PM
georgedavila georgedavila is offline
georgedavila is starting off with a positive reputation.
I removed the thermostat, replaced the upper hose, parked it going up a slight incline, motor running with the heater water circulation on and 'burped it' by squeezing the upper hose.
Old 07-17-2002, 10:27 AM
I'll try it tonight. How do you know when it's been "Burped"?
Thanks!
Old 07-17-2002, 07:08 PM
your coolant level will drop.
Old 07-17-2002, 07:56 PM
Pilotrick Pilotrick is offline
Pilotrick is starting off with a positive reputation.
Does your thermostat have a little whole with a piece of metal (bleeder valve) that moves around in it? If it does make sure it is at the 12 o'clock position and that the little piece metal moves freely this will allow the air to bleed out. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Tags
1996, air, bronco, burp, burping, coolant, cooling, dual, expedition, ford, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
