oil pressure switch= no start
My buddy with a 99 psd shut it off and it would not start, checked fuel system and it was good. I suggested a cps but that did not work. A guy drove up claiming to be a ford mechanic said it was the oil pressure switch, said it is very common for theese trucks. He wants to take mine out and stuff it in his truck and Im not real comfortable with that. Can you unplug that SWITCH and jump the two wires togather?
If the IPR is at fault, you could just unplug the wiring harness from it as a test. If the PCM cannot read from the IPR, then it defaults to a standard table of values to keep the truck running. If the truck runs (or starts) better with the ICP unplugged, then you have found your problem. Easier than going through the trouble of swapping it out.
Originally Posted by hedhntr
Its the one on the back side of the hpop.
Edit: The one I'm talking about is on the HPOP resivoir, not down further where the pump is mounted.
MONAVIERONJON
07-06-2014 12:19 PM
wally4684
05-11-2014 09:03 PM
fixitman1310
33
05-30-2011 12:51 AM
strokin'_tatsch
01-09-2011 10:23 AM
