Which Transmission Cooler?
I'm going to suggest this one. http://www.dieselsite.com/index.asp?...ROD&ProdID=205 Installation is a snap and the performance is great. Some will also suggest the 6.0 OEM cooler. And yes, BTS uses it. But like i said. The True-Cool Max has performed very well for me towing the TT in 115 degree temps on real western mountain grades.
Hope this helps.
Regardless of which you choose, it will be big time better than the stock setup you're running now.
Hope this helps.
I would say go with the 6 litre cooler. Im thinking of upgrading as well to it even though i have the v-10 cooler. Im also considering doing a radiator swap as well so i got cooling through the raditor as well. Im in the city alot in the summer with loads in the back and i start to get scared at 180degrees.
Trigger200
1997 - 2003 F150
06-07-2009 05:27 PM
Alvin Tim
11-30-2006 09:26 AM
conan8
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-19-2005 07:37 PM
