today i was driving and i had my window down..and when i started to row it up it would get stuck then eventually it would go up?? it's on the drivers side..
sounds like your wiring may need to be repaired. could be a bad ground
i have a problem with my window when its hot outside. It wont work in that temp. it turned out to be a bad connection.
Good luck
