Dtc P2004 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Dtc P2004
Old 03-11-2007, 01:16 PM
mike yates mike yates is offline
mike yates is starting off with a positive reputation.
Dtc P2004
Hey everyone. I need some help with the following DTC P2004.
My check engine light has come on on my 2003 Ranger 2.3L 4V equipped Ranger.
I have a Stinger code reader which shows a trouble code P2004. I havn't been able to find out what this code means. Does any one here have a clue?
Thanks
Old 03-11-2007, 01:36 PM
fflintstone's Avatar
fflintstone fflintstone is offline
fflintstone is starting off with a positive reputation.
Didn't have time to look it up but its under Emmissions - OBDII Codes
http://www.ford-trucks.com/forums/10...formation.html
Old 03-11-2007, 01:39 PM
crazypaw's Avatar
crazypaw crazypaw is offline
crazypaw is starting off with a positive reputation.
Talking Hey Newbie!
Old 03-11-2007, 01:40 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Welcome to FTE mike.
P2400 = Evap Emiss Sys Leak Detection Pump Control Circuit Open.
On edit: WOOPS crazypaw I'm not on top of it today, transposed some numbers as I was writing them down & Nannie was hollering at me!!!! lol
Trouble Code 2004 = Intake Manafold Runner Control Stuck Open Bank 1
Last edited by pawpaw; 03-11-2007 at 02:16 PM. Reason: woops, posted wrong trouble code
Old 03-11-2007, 01:42 PM
crazypaw's Avatar
Talking Hey Flintstone!
Were both on top of this one ain't we??
CCCCOOOOOOOOLLLLLLLL!!!
Have to also say Welcome GURU!!
Old 03-11-2007, 06:05 PM
crazypaw's Avatar
Exclamation Trouble Code 2004
Hi mike yates,
Well what did you do about it???
WAIT A MINUTE: Crazypaw here: HEY GUYS! I went back into the OBDII codes @ 7pm and page 55 is blank, page 54 only goes to code 1900...NOW WHAT?...hold on yates we'll get you an answer!
Old 03-11-2007, 06:28 PM
Dtc P2004
Woo Hoo! All I have to do to get an answer is get hooked up with the right bunch of guys. Thanks everyone, I looked through to tech info link posted by crazypaw but the codes didn't go to P2004. I saw the same thing in the repair manual I bought. I also saw this code listed on a Mustang forum as being the same as what Pawpaw posted (Trouble Code 2004 = Intake Manifold Runner Control Stuck Open Bank 1). So what is an intake runner control, what does it do and are you guys sure this engine has one? Again, this is the dual overhead cam 2.3L 4cyl engine. I want to try and resolve this myself without going to the expense of having a dealer look at it.
I should point out that other than the Check Engine light being on, the truck drives just fine. You can't tell anything is even wrong with it. The motor runs real smooth and still gets 24MPG.
Thanks
Old 03-11-2007, 06:42 PM
crazypaw's Avatar
Red face Where is my Code??
Hi mike yates,
Your looking for way to fix your baby...I know!
I just went searching for your code @ 7pm and realized it's not there (should be on page 55...but it's blank!)
This is not a good starting @ FTE for you...I know!
I'm trying to work on a resolution...hang in there!
Old 03-11-2007, 06:51 PM
crazypaw's Avatar
Hey GURU:
crazypaw here c/o mike yates:
http://www.ford-trucks.com/forums/589641-dtc-p2004.html
DTC P2004 is not in KENOO's Tech info Section; Page 55...now what?
Old 03-11-2007, 08:05 PM
<TABLE cellSpacing=0 cellPadding=4 width=575 border=0><TBODY><TR><TD>
Anatomy of the DTC
<SMALL>A DTC is made up of 5 digits. The figure below demonstrates the composition of a DTC. With this information it is easier to trouble shoot a DTC without knowing the description of the code.</SMALL>
</TD></TR></TBODY></TABLE>
According to this chart I got off OBDII.com the second digit does'nt have a 2. But I'll keep checking
Old 03-11-2007, 08:13 PM
Mike
Are you sure it's not P0204
<TABLE width="100%" align=center border=1><TBODY><TR><TD vAlign=top>P0204</TD><TD vAlign=top>Injector 4 Control Circuit</TD><TD vAlign=top align=middle colSpan=6>Generic OBDII Code </TD></TR></TBODY></TABLE>
Just a thought
Old 03-11-2007, 08:28 PM
Yes I'm Sure. If you do a web search for that code, you'll find that it's out there. I found one on a Mazda site that describes it as "Variable Tumble Control system shutter valve stuck open" what ever that is.
I found another at stangnet.com. It describes the code as "Being associated with the charge motion control valve(CMCV), actuator motor, and/or linkage concerns." But that was on a 2005 Mustang, 2006 Explorer and 2006 Mountaineer.
I did a search on Google using DTC P2004 as my search item.
Old 03-11-2007, 08:31 PM
BTW, My book has the same chart as above. It doesn't show a 2 as the 2nd digit either. That's why I'm here talking to you nice people. (-:
Old 03-11-2007, 08:58 PM
OH NO!!! They should have called the silliy thing OBD III. Don't they know are lives are complicated enough with trying to figure out some of this mumbo jumbo . When the bloody h*ll did they update OBD II???. Leave it to an engineer to make it 'Better'. Not to insult all engineers out there, just the one who made that decision. But I'm sure he has a perfectly reasonable explaination that would take two hours to read and six years to understand.
BOY!!! Oh well. We plod on.
Old 03-11-2007, 09:45 PM
Well mike, what does your repair manual say about the type of intake manafold you have on your 2003 2.3L 4 banger?????
I remember reading some where about a split induction manafold, maybe you have one on your ride & the motor, or circuit that controls it, is acting out.
I don't now squat about the 4 banger engine, so maybe someone with the newer modle will chime in.
2004 Ford E250 4.6 V8 trouble codes rustyandleaking 1968-2013 Full Size Vans 3 12-30-2016 02:16 PM
DTC codes P006A & P132B SuperDuty Bundy 6.0L Power Stroke Diesel 3 04-13-2016 11:15 PM
DTC Codes P0678 & P0675??? Militant83 1999 to 2016 Super Duty 5 09-05-2014 01:14 AM
2004 f150 transmission malfunction drew2004f150 2004 - 2008 F150 1 07-09-2013 01:15 AM
2004 f150 dtc p2106 5.4 3V mailmanshears 2004 - 2008 F150 11 09-20-2010 07:23 PM
Tags
02, 2002, 2004, 23, actuator, bank, code, control, f150, ford, imrc, intake, manifold, monitor, open, p2004, pic, picture, ranger, runner, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
