Dtc P2004 - Page 3 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Dtc P2004
  #31
Old 12-27-2007, 10:27 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
On the '03 2.3L there is something called a "Swirl Control Solenoid Valve" assembly which is "a manifold–mounted vacuum actuator and a PCM–controlled electric solenoid, with the linkage from the actuator attaching to the manifold butterfly plate lever." I would suspect the P2004 problem lies somwhere in this.
  #32
Old 12-28-2007, 04:26 PM
mike yates mike yates is offline
mike yates is starting off with a positive reputation.
Thanks a lot for the info. Unfortuately A drunk driver hit me in the rear and rolled the truck 6 times. It's a total lost as you could imagine. So I don't have to worry about it now.
  #33
Old 12-29-2007, 07:55 PM
03ocxlt 03ocxlt is offline
03ocxlt is starting off with a positive reputation.
Thanks for the info. Ill have to look into that. I just got back in town and went 354 miles on 13.9 gallons of gas. Averaged out to right at 25.2 mpg. My truck seems to be running fine. I just want it say its running right. Ill let yall know what I find out when I get around to looking at it.
  #34
Old 03-29-2008, 08:32 PM
ScootieRngr ScootieRngr is offline
ScootieRngr is starting off with a positive reputation.
I'd like to reopen this thread. We have a 2002 Ranger with the 2.3 and have code P1537 for the IMRC being stuck open.
I would like to test the diaphram assembly and would like to know the amount of vacumn required to start opening (and coompletely open) the diaphram. I'm afraid my breath isn't as good as it used to be, although I can hear something moving when I try it.
I'll run a test on the vacumn selenoid switch in the morning.
  #35
Old 07-10-2008, 04:26 PM
Goodbye Goodbye is offline
Goodbye is starting off with a positive reputation.
Dtc P2004
After reading through three pages and finding no answers on this problem, I just went out and looked for it on my Mazda B2300(Ranger). Found it right away. It's a small vacuum solenoid just under the intake manifold but above the starter. The bottom vacuum line going into it was broken, most likely because it's a bit short and was bent funny, plus engine bay heat and such. So for anybody else with this code, check that solenoid first, it's a 30-second freebie fix.
  #36
Old 07-30-2008, 02:38 PM
stingrayauto stingrayauto is offline
stingrayauto is starting off with a positive reputation.
"Goodbye" We just had a B2300 come in with the code everyone has discussed above. It was exactly the hose you said it was. Thanks for posting the information.
  #37
Old 07-30-2008, 03:26 PM
No problem, glad I could help.
  #38
Old 09-07-2008, 04:28 PM
1995sho 1995sho is offline
1995sho is starting off with a positive reputation.
how to clear the code (P1537) after fix?
Hi. My Dad has a 2002 B2300 with the 4 cylinder engine and it had this same code (P1537). We followed the advice given before; look for a bad vacuum line going into the IMRC solenoid and sure enough the lower vacuum line was cracked. We replaced it in about 5 minutes but now the "Check Engine" light is still on. I was hoping by replacing this line, the "Check Engine" light would go off but it hasn't. Does this particular fault require a "reset" command via the OBD II port or will it reset itself after a certain number of "off/on" cycles of the ignition switch?
I'm hoping it just needs to be reset via the OBD II port because if it was supposed to have gone off immediately after the fix, it means we have another problem.
Thanks for reading this, Scott
  #39
Old 06-01-2009, 09:33 PM
crazyredneck_21 crazyredneck_21 is offline
crazyredneck_21 is starting off with a positive reputation.
This is helping a lot cuz my girlfriends 05 focus is throwin the same code but as the ranger seems to run fine. i think im gonna try the sea foam on it and see wat happens. thanks for all the info.
  #40
Old 06-02-2009, 09:43 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
The check engine light should go out after three cycles without an error code. Just keep truckin'
Check the codes again if it doesn't go off.
  #41
Old 01-11-2010, 08:43 PM
Leather Head Leather Head is offline
Leather Head is starting off with a positive reputation.
Broken Vacuum Hose
Thanks for the great advice posted here, All.
Replacing the vacuum hose fixed my P2004 error on a 2003, 4 cyl, Auto.
I was surprised that the light went out immediately...no need for 3 start/stop cycles.
Extra clarification: The valve is located under the intake manifold near the firewall.
  #42
Old 01-11-2010, 09:11 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Welcome to FTE.
Good find, fix, feedback & to hear you found a quick resolution of your problem.
  #43
Old 03-24-2010, 08:15 AM
chuckd3point0 chuckd3point0 is offline
chuckd3point0 is starting off with a positive reputation.
just fyi i won a 2004 ford f-150 and am receiving the same error code.along with a few others for the system running to lean. But if it is not takin care of youll end up like me, im getting backfires and the truck "shudders" at certain points in in slow acceleration.Im currently trying to find a way to fix it the cheap/correst way ill keep you posted : )
  #44
Old 10-01-2012, 03:57 PM
greasemonkey11 greasemonkey11 is offline
greasemonkey11 is starting off with a positive reputation.
im actually a mechanic and working on a 2003 ranger 4 cyl. 2.3 L and yes i would inspect the vacuum hoses at the intake. For the one im working on the outer shell that holds the hoses to the solenoid has come apart which is why the code of P2004 was set. Very easy and inexpensive fix.
2004 Ford E250 4.6 V8 trouble codes rustyandleaking 1968-2013 Full Size Vans 3 12-30-2016 01:16 PM
DTC Codes P0678 & P0675??? Militant83 1999 to 2016 Super Duty 5 09-05-2014 12:14 AM
2004 f150 transmission malfunction drew2004f150 2004 - 2008 F150 1 07-09-2013 12:15 AM
Dtc P1249 ?? blksiryder 1999 - 2003 7.3L Power Stroke Diesel 7 08-22-2007 09:06 PM
1999 Ford Ranger DTC P 1405 redray59 Ranger & B-Series 7 12-10-2003 06:24 AM
Tags
02, 2002, 2004, 23, actuator, bank, code, control, f150, ford, imrc, intake, manifold, monitor, open, p2004, pic, picture, ranger, runner, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
