Weird fan noise
Weird fan noise
OK, been trying to figure out what the hell I was hearing from the engine, and now I've figured it out - but don't understand it. It is a grinding noise coming from the fan, but it only does it when I turn left and either going up or down an inline/decline. I tried to get it to do it when on level ground - no go. I'm stumped!! ANyone else have this problem, or know what could possibly cause this??
Weird fan noise
I had the same problem with my Bronco. It turned out to be my motor mounts. The two on each side of the engine had been bad and it caused the engine to fall therefor the fan falls. It may only make the noise sometimes because the fan does have some extra room around the shroud.
