Salt in SD? - Ford Truck Enthusiasts Forums
Montana Chapter Join Chapter , Leader: Sailor_Roy
Salt in SD?
Old 03-10-2007, 09:16 PM
Blue50F-1's Avatar
Blue50F-1 Blue50F-1 is offline
Blue50F-1 is gaining momentum as a positive member of FTE.
Question Salt in SD?
This may seem like a really silly question, but I can't seem to find an answer anywhere else...
I may be moving to South Dakota before too long, and was wondering if anybody could tell me if they treat their roads with salt in the winter.
They use a little bit of salt here in KC, but we don't often get enough snow to warrant it, so I usually don't have to worry much about rust.
So, anybody know if they use salt in SD?
Thanks!
Old 03-11-2007, 07:33 AM
1979 Ford's Avatar
1979 Ford 1979 Ford is offline
1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold
I will check. I am thinking it is a salt sand mix of some sort. Next time I visit with someone from the DOT I will ask.
What part of South Dakota are you looking at?
Old 03-11-2007, 08:19 PM
Blue50F-1's Avatar
Looking at Eastern SD. 3 towns in particular. Watertown, Brookings, and Vermillion. Nothing's said for sure, but my wife and I are trying to get an idea of what it would be like up there in case we do end up going there. Since I drive my 50 most days, and our family hauler is (or rather, will be, in Sept when our kid's born) a 66 merc, I'd like to know how worried I need to be about corrosion, and if we'll need to buy something less fun (but more practical) to haul around in (other than the 4x4 pickup we use on bad days now).
Another place we may end up is the Chicago area. I know they use a lot of salt there (lived there for a few years in the late 90's), but where I grew up (Oregon) they used sand.
Old 03-15-2007, 08:36 AM
Dave Severson Dave Severson is offline
Dave Severson is gaining momentum as a positive member of FTE.
The South Dakota DOT and most municipalities use a salt and sand mixture. Not near as heavy a concentraition of salt as some other states. Just make sure whatever you drive in the winter is undercoated well....
Old 03-15-2007, 04:35 PM
Blue50F-1's Avatar
Thanks Dave. The Merc's in progress, but I plan on undercoating it with a rust inhibitor, and a rubberized undercoating. The 50 is already undercoated, so we're in good shape there. Thanks again for the info.
James
Old 06-27-2007, 02:00 AM
76390CI 76390CI is offline
76390CI is starting off with a positive reputation.
I live in western SD and I would not recommend driving a classic very much in the winter around here. There is a mixture of salt and sand (gravel if you ask my windshield) that is put on the roads when it snows.
Old 06-27-2007, 08:38 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
In the cities, yes, salt. In the country, sand... Sioux Falls is terrible about their salt usage, but not as much elsewhere... You can always tell a vehicle that has spent many winters in Sioux Falls, by the rust... Other vehicles that are out away from there have next to no rust... I picked up a 79 F250 a while back that had one area of rust, over the fenderwells on the box, and that was about it. Many other vehicles I got while I lived out there same story, not much rust. Vehicles here in Iowa have way more rust...
One thing to remember, it can get too cold for the salt to work, so most of the time, they tend to use dark colored sand/ash to get the heat of the sun to do the melting.
Old 06-27-2007, 10:47 AM
Blue50F-1's Avatar
Sweet! Thanks for this late breaking report. We will be headed to SD (unless something wierd happens) the beginning of next year (probably the second week of January). We still don't know where exactly, but it will not be in Sioux Falls. We're taking a trip up there this weekend to check out four places, and we'll see where things go from there. (We're headed to Brookings, Watertown, Vermillion, and Yankton btw.) Sounds like I probably won't have to worry about too much salt in any of these areas. Thanks!
Off topic: What's a "GMC Transform Your Ride Sale" ad doing in FTE? That seems wierd.
Old 06-27-2007, 01:26 PM
fellro86's Avatar
Brookings is not a bad town, but the pricetag is a bit high, Watertown is pretty good as well, but can't answer on price. Vermillion is another college town, and Ynankton isn't too bad, but I have no clue on the living there. Pricewise, probably higher, but it depends where you are at for pice as to what you consider high... Put it this way. I had a house out to Iroquois, cost $26,000, not a bad house. Same house in Brookings would be about $100,000.
Yankton and Vermillion will be more likely to use salt too, as they are further south. I was in the Huron-Brookings-Watertown area. Worked in Brookings for 5 years... I have been to Watertown a number of times. Depending what you are wanting, don't discount Aberdeen, that town has it going on, especially for being out as far as they are...
Old 06-27-2007, 09:21 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
The ads are just to keep the lights on... I think its all a generic ad creator.
I think they use boulders on the roads up here... the Jeep gets a new windshield every May. The truck usually makes it two years between windshields.
Old 06-28-2007, 07:02 PM
1979 Ford's Avatar
Quote:
Brookings and Yankton are nice towns. Vermillion doesn't impress me a whole lot.
If it wasn't for USD Vermillion wouldn't be missed.
Warnning For All 04 -08 F-150 Ownners Seasprite 2004 - 2008 F150 29 05-13-2016 07:50 PM
New tailgate prep hivoltj 1978 - 1996 Big Bronco 3 02-14-2016 08:11 PM
On the topic of rust Ford SD 1987 - 1996 F150 & Larger F-Series Trucks 1 04-09-2015 12:11 PM
clearance lights Salts Appearance & Dress-Up 15 08-29-2014 09:35 PM
question about fluid film application fordman19762003 1999 to 2016 Super Duty 6 10-13-2012 01:01 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
dakota, madison, roads, salt, sd, south, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
