1997 Ford Explorer 4 wheel drive XLT - Transmission - Ford Truck Enthusiasts Forums
Old 03-10-2007, 05:30 PM
rblatch45 rblatch45 is offline
rblatch45 is starting off with a positive reputation.
Hi all. Left at 2:00 am this morning from Baltimore and drove fifteen hours to Florida. About three quarters of the way here, either my transmission or my transfer case started acting up. While cruising at 75 or 80, I have no problem. However, whenever I let off of the gas, or brake, I get a high pitched whineing sound coming from the area of the engine transmission connection.
If I lightly step on the gas, the whineing would stop again. It seems as if something was still "spinning" the same speed as it was before I applied the brakes and was not either disengaging or reducing its spin speed with the reduction in the engine speed.
Any help or suggestions would be appreciated. Being out of town is certainly a handicap. If this is a known problem, an appropriate amount for repair or guideline would be appreciated also. Thanks.
Cordially,
Bob Blatchley
Looking for Body Shop ezrdr54 Maryland Chapter 1 01-12-2015 06:47 AM
Whining Sound upon Braking at highway speeds..? Violeta Explorer, Sport Trac, Mountaineer & Aviator 2 08-02-2011 08:29 PM
Experience with MD Performance Deisel GSlahor Maryland Chapter 3 03-03-2011 09:35 AM
truck only creeps forward. Dimitri.c 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-23-2009 09:15 PM
New comer via 171/174 lean condition 97 silver 4.0 New Member Introductions 1 04-17-2008 06:30 PM
Tags
1997, 97, cylinder, drive, duty, explorer, ford, heavy, information, prices, related, transmission, transmition, wheel, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
