Bench vs. Buckets - Ford Truck Enthusiasts Forums
New Jersey Chapter Join Chapter Leader: sddesigns
Bench vs. Buckets
Old 03-10-2007, 05:13 PM
mrfox0246 mrfox0246 is offline
mrfox0246 is starting off with a positive reputation.
Bench vs. Buckets
Greetings - I'm building a '54 F100 and need a bench seat . Northern New Jersey area. Anyone know of someone parting out a mid 80's and up pickup? No luck in salvage yards, pickups are usually picked clean within a day or 2 around here.
Hope I'm notbreakin any "Buyin',Tradin', swappin" rules here. PM or Email is fine
Thanks -Rich
Old 03-11-2007, 05:58 AM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
I have a red one with two headrests from my 93 crewcab. Though I recycled the tracks so they wouldn't be included. You'd need to fabricate them anyway to fit the bench into your 54. PM me if you're interested, I'm in 07067
Old 03-14-2007, 05:21 PM
frederic's Avatar
Guess not. *shrug*
Old 03-14-2007, 07:17 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
ya scared mrfox away!!!
maybe ya gots ta put a hat on.?..
Old 03-15-2007, 02:00 PM
Sorry -- got caught up in hopme stuff and haven't checked the forum. No disrespect intended. Thanks frederic for the offer, I'll need to check the width of my cab (no doors on it now) to see what'l fit. Also don't know how difficult/easy it'd be fabricating brackets/tracks.
Old 03-15-2007, 09:32 PM
frederic's Avatar
No harm done at all. I moved the bench seat from the back of the garage to the front in case you were seriously interested in it. No biggie.
Fabricating tracks is a pain in the ****, since you found crummy bench seats in the boneyard, grab the tracks. Then making mounts is as easy as welding some 1/4" plate to the bottom of the tracks and drilling through those plates to your floor, using larger fender washers underneath assuming the floor is solid.
If not, you put a plate underneath the upper plates, drilling them together before welding so you can line them up properly on the floor and drill through.
Another option is to use hat nuts, i.e. nuts with a built in cast washer that's part of the nut. Push them through holes in the floorpan so the flange keeps it from passing through, then weld the flange underneath to the floorboard.
There's 20 ways of doing this that are fairly easy. Just use good hardware as ungraded bolts will snap in an accident. I always use grade eight for fabricated seat things simply because I want to stay inside the truck.
Old 03-25-2007, 08:44 PM
geleonardjr's Avatar
geleonardjr geleonardjr is offline
geleonardjr is starting off with a positive reputation.
Hi-Still looking for a bench seat? I have one from a 1986 F150 XLT regular cab so it folds forward. Its blue cloth sort of like velour and in very nice condition-not worn, no rips, or tears. I live in Hopatcong, NJ. If interested, let me know. $100
Old 03-25-2007, 08:49 PM
Absolutely, thanks - I'm in Dover - email me? mrfox0246@optonline.net
Many Thanks
Old 03-26-2007, 08:08 AM
Email: gleonard@kean.edu Telephone: 973-222-6297 Ill be in Dover today. If its convenient for you, we can meet.
replacing rear bench with captains chairs? buttonwood Excursion - King of SUVs 8 01-31-2015 05:40 PM
E350 15 passenger bench seats CHEAP!! carrfamilynj 1968-2013 Full Size Vans 0 10-26-2014 02:47 PM
Parts thatsrealnice 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-10-2010 01:29 PM
Split Bench Seat CowboyUp96 1987 - 1996 F150 & Larger F-Series Trucks 11 03-17-2010 10:37 PM
Seat foam for bench seat on 51?? sancochojoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-06-2006 07:46 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
bench, bucket, buckets, gleonardkeanedu, seats, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
