Stick on oil pan heater
Has anyone tried the stick on oil pan heaters from JC whitney? I live in alaska and it can get pertty cold here. I need something more than the block heater when the temp drops below -20. Also been looking for a recirculating heater instead of the block heater I had no luck finding one on the internet.
2003 F250 6.0 FX4
2003 F250 6.0 FX4
If I lived where it got consistantly frigid, I'd look into one of these.
http://www.webastoshowroom.com/blueheat/
Zerostart makes circulation heaters, but it doesn't look like they have an application for the 6.0L.
Good luck in your efforts.
I installed the Wolverine Model 16 about 3 years age, spliced the wires into the block heater plug and am amazed at how smooth startups are and how quickly the heat blows inside. Both heaters together use 1200 watts so I use a regular outdoor timer from Home Depot set to start 3 hours before I start the engine. Unless I'm mistaken, at 10 cents per kilowatt hour my 3 hours usage daily costs me 36 cents.
So JC Whitney is still selling that stick on block heater.
Go ahead and get it but be aware that it does get HOT and does pull SOME juice. If you plug it and the stock heater into the same outlet CHECK your breaker!
ps: it does get cold in Tx we went a month without getting above 32 and that stick on heater kept my 460 jet boat nice and warm.
2003 F250 6.0 FX4
2003 F250 6.0 FX4
If I were you I'd look around at some of the suggestions that the other folks have told you about.
Gunner15a
We have an '05 Passat TDI that doesn't have a block heater provision. One of the 'stick-on' heaters I looked at req'd the paint on the pan to be sanded down to bare metal. I didn't like that idea but I guess if it was removed, it could be repainted.
A custom circulation heater is available, but I haven't made a move on one. Zerostart makes the base heater, but they don't show an application for the 6.0L. Probably because they are all supplied with the block heater, and the cord is available . (if it's not already installed)
Take Care
Take Care
Firefighter 1406
10-17-2016 07:35 AM
