Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 03-15-2007, 11:21 AM
LaredoF350's Avatar
LaredoF350 LaredoF350 is offline
LaredoF350 is gaining momentum as a positive member of FTE. LaredoF350 is gaining momentum as a positive member of FTE.
I just bumped this up hoping someone would know if it works with CDN trucks with drl's. Over at TDS there is something referred to as the 'steveracer mod' that accomplishes the same thing but I havent researched it yet.
__________________
2008 F-250 Lariat SRW 4x4 CC SWB ...
... 6.4L & Torqshift w/3.73
... Dark Stone Metallic / Pueblo Gold
... Readylift levelling kit w/caster cams
... Toyo MT 35-12.5-18
BIG$HOW --«Õ¿Õ¬»
  #17 (permalink)
Old 03-15-2007, 05:57 PM
rwilimo rwilimo is offline
rwilimo is starting off with a positive reputation.
I would think that it would work. as Far as I remember DRL's only affect the low beams, so I don't think that would be a problem.
  #18 (permalink)
Old 03-15-2007, 06:07 PM
zed326 zed326 is offline
zed326 is starting off with a positive reputation.
does it go for 05 also??
  #19 (permalink)
Old 03-15-2007, 06:36 PM
mpeck reported on page 1 of this thread that it worked fine for his 07 so I would have to think it would work for you also.
  #20 (permalink)
Old 03-15-2007, 06:56 PM
Netfly's Avatar
Netfly Netfly is offline
Netfly is gaining momentum as a positive member of FTE. Netfly is gaining momentum as a positive member of FTE.
Yes Zed326 it does. I did mine. Very easy and simple mod. Here is another write up on it:
http://www.ssdiv.com/fogfix.html
From the pic above it looks like rwilimo added a fuse in line to ground? If so that is not needed.
__________________
  #21 (permalink)
Old 03-15-2007, 07:21 PM
Quote:
No not a fuse, that is a male and female spade connecor.
  #22 (permalink)
Old 03-15-2007, 08:20 PM
LaredoF350's Avatar
The article says it wont work on trucks with DRL's. I have also heard of a product called the britebox. Anyone familiar with this?
__________________
BIG$HOW --«Õ¿Õ¬»
  #23 (permalink)
Old 03-17-2007, 03:39 PM
Joms Joms is offline
Joms is starting off with a positive reputation.
I just did this Mod to my '04 F250 6.0 today..about 2 hours ago. After I did it I attempted to test it and could not get the fog lights to work at all. I didn't have time to continue messing with it so I started my truck to let it warm up and was going to leave when I noticed they were on. I did the first test without the truck running, just the headlight switch on. Come to find out...at least on my truck...the headlights, both High and Low beam, will work without the key on, but the fog lights require the key to be on. Just letting you know so you don't have the same confusion that I had as first...
  #24 (permalink)
Old 03-17-2007, 07:03 PM
112233 112233 is offline
112233 is new and has a neutral reputation at this point.
ok ..worked fine on the replacement 07 we havehere..but got a new and bigger question for all the gurus out there...
i would like to keep the high`s and lows on at the same time when i switch to the high beams. ya i know the head light mod, but... when i did the mod mentioned in the forum,....... did nothing but blow fuses. i had a set of adapter plugs i bought from an indiana firm for the o1 we had, and used the religeously on every truck till the 05 (lemon from hell), but lost them in a house fire we had here last september. ( lightning ) I can not recall the company info as to where i got them, (19.95 usd) from what i can recall, but if the mod??? is still working for the 06/07`s i would like to attempt this, or???? buy another set of these finely made plugs... any brain stoming ideas appreciated. sorry, not attempting to hi-jack any thread, just thinking along the lines of getting more light!!!!! (damn pesky deer).
  #25 (permalink)
Old 03-17-2007, 07:09 PM
I have not heard of that being done on the newer trucks because apperently the heat gets too high in the housing then? I would also like to do this but I have always wondered about the heat factor. If someone could get me the wiring diagram I could modify it to make this work the way you want. The only other way I can think of is to use 2 relays and a few diodes behind the drivers side headlight.... You could put the diodes behind the stock relays but I dont know the color of the cables coming out of the fuse box...that is where the diagram will come in handy...
  #26 (permalink)
Old 03-18-2007, 12:13 PM
LaredoF350's Avatar
Could something be accomplished through the dimmer switch? When pulled back, everything comes on.
__________________
BIG$HOW --«Õ¿Õ¬»
  #27 (permalink)
Old 03-18-2007, 08:39 PM
Netfly's Avatar
Here is some info on Brightbox:
http://www.ford-trucks.com/forums/56...hi-beam-2.html
and wiring harness upgrades:
http://www.ford-trucks.com/forums/54...t-harness.html
and a retailer page:
http://www.gosracing.com/fd_acc
__________________
  #28 (permalink)
Old 03-19-2007, 09:54 AM
Bernie Lomax Bernie Lomax is offline
Bernie Lomax is starting off with a positive reputation.
Worked on my 04. Took about 10 mins. Thanks very much!!
__________________
2008 F250 XLT Supercab
  #29 (permalink)
Old 03-19-2007, 11:43 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation.
Nice thread! Should make a tech article on this one
If I remember, I'll check my '01 EVTM to see if it'll work on the earlier ones. Probably, but can't be sure without checking the schematic.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #30 (permalink)
Old 03-19-2007, 09:33 PM
LaredoF350's Avatar
So what is coming on - highbeams and fogs or - highbeams lowbeams and fogs? I still cant seem to find answers about making things work with DRL's so I will make some phone calls in the next few days.
__________________
BIG$HOW --«Õ¿Õ¬»
Tags
02 , 2001 , beam , black , bosch , f0az14n089a , f350 , fog , head , headlamp , high , lamps , light , lights , video7105comcastnet , wire , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
