throttle linkage - HElP!!!
I have looked everywhere and I just can't find any throttle linkage, my linkage right now is bent, so im only getting about half throttle. I bent it back once already, but it bent back, and if I keep bending it back it's just getting weaker.
So if anyone knows where I can get one, PLEASE HELP!!!!!
First, welcome to FTE! The official greeter will be along shortly. Now, in order for us to help you, we need information. I see you've got a '67 F100, but what engine/carb is under the hood? If you could, maybe add a picture of the linkage that needs replaced? I'd be willing to bet that some of us would have the part you need.
Last time I needed a part, I hit the local salvage yard for a few hours of fun. :-) Let us know what you need!
Originally Posted by motoxtj
Ok, i have a 352 vin code Y engine, and a 2V carb.
I tried to add a pic of the linkage but its not working for some reason.
What transmission do you have?
ok, i've uploaded 2 pics of the linkage.
I have a 3-spd manual. What does that have to do with the throttle linkage though?
2 Rods to Firewall~Upper Rod = D0TZ-9D702-A / Lower Rod = C7TZ-9A702-B
Short Rod nearest left valve cover = C6TZ-9772-A
Long Rod adjacent to carb = Rod is not shown in acc linkage picture. Note: C7TZ-9A702-C is nearly identical, and might be an omission in the parts book pics/text for F100/350. It's listed for and shown under = 1965/72 F500/600.
These parts are the same/similar to std trans applications: 1965/72 FE engines
on
Originally Posted by 390fe
First, welcome to FTE! The official greeter will be along shortly...
So Hi Tyler, and Welcome to FTE! Please take a moment to check out the Guidelines (if you haven't already done so) as they contain important info that you'll need when posting on the site:
https://www.ford-trucks.com/guidelines.html
And we'll se you around!
