AC Compressor install help
My A/C compressor gave out on my 94 F150 5.0 EFI.. I got a brand new one, with also the Dryer, and some kind of small filter. Ive got the dryer installed, and the compressor, but i was also givin a small amound of ester oil, im not sure how much to use and where. And also, i dont know where to replace this filter at. The filter is narror and about 3 in. long. Any help with where to replace this filter and how much of this oil to use would be great.
Thanks
Thanks
Ok, so this is where im at. I found out to put around 5oz. into the compressor, and about 2oz. into the Dryer. I have it all installed. No when refilling with R134a. I turned the A/C to max, and connected to the low line and started my fill. Halfway through the first can i was able to fill to 45psi, (max fill pressure), and the compressor would not enguage. So i jumped it. I let it run for a minute and then started to fill more. With the compressor on, my pressure guage reads 0psi, but when i disconnect the my jumper to disenguage the compressor it will read right at 45psi. Right now the compressor is cycleing. With the guage connected to low side it will rise to 45psi, the compressor kicks on, the pressure then will drop to 20psi(lowest operating pressure) here the compressor kicks off. Any thoughts on this?
The quick cycling is normal when the charge is low.
You can keep the jumper on until you fully recharge the system.
Then take the jumper off.
I hope you pulled a vacuum before you started the recharge.
Keep an eye on the high side pressure. It varies from system to system but it should not exceed the 300 psi range. If it does, stop because you have a blockage some where.
The little screen you purchased is called the orifice tube. It controls the refrigerant flow in the system. There is a u shaped tube with a spring lock connection at the evaporator housing. the orifice tube is inside the metal tube. There is a special tool that hooks on to the orifice tube so you can pull it out. You can also use a long drywall screw. It will destroy the old orifice tube but it's one way to get it out if you don't have the proper tool. That screen can get clogged by small particles so you should have replaced it or cleaned it.
When the compressor is off, the pressure will be the same throughout the system. Once the compressor starts running is when you get your pressure differential. High side pressure goes high, Low side goes low. The pressure you want to watch is the Low pressure side while the compressor is running. That is your fill pressure.
There is an A/C forum on this site. I would suggest you go take a look at it. All of this type of stuff has been covered there many times.
The small screen is an "Oriphis tube" it is in the tube that runs from you're reciever/drier into the tube that goes to the e-coil (evaporator coil) you'll need a tool like a fuel line disconnect tool to undo this. They can really be a pain in the *** to get out. It catch's debri in the system.
If it isn't replaced the warranty usually is voided on the compressor.
Tim Young
07-26-2016 08:26 AM
Vic93
08-01-2013 05:55 PM
