Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Competition Diesel racing, sleds, dynos, power tuning and max performance.
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-08-2007, 12:20 AM
6L PWR's Avatar
Duct Tape Specialist
6L PWR is gaining momentum as a positive member of FTE.
Coolingmist or Snow Performance??
I'm thinking of adding a Water/Meth injection system to help lower the EGT's a bit. Which one is the best?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-08-2007, 01:29 AM
phil6608's Avatar
phil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud ofphil6608 has much to be proud of
I run a stage 2 Snow kit on my gas-er. I like it and It works great. Never had a problem with it.
__________________
Phil
DE Chapter Board Member/New Castle County
2003 SuperCrew
DSS Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 18 PSI
BTS/4R100 tranny
100 shot nitrous
1.68 60' time/11.76 @ 116.17
TRUE GRIT!
2000 Grand Marquis
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #3 (permalink)
Old 03-08-2007, 01:57 AM
Industrial_dude's Avatar
Industrial_dude is starting off with a positive reputation.
I run the snow performance stage 2 kit and think its a waste of money. It cools down the temps but unless you install a huge tank for the waTER/methanol youll have to keep filling up the tank every half hour of towing. worthless to me atleast.
__________________
04 EX 6.0 mods: u name it I prolly got it
07 Ranger 4x4 Tremor pkg
07 Kawasaki ninja ZX6R
07 Eliminator 30ft eagle twin HO's
06 KTM 450SX
04 RMZ250
02 TPD 28ft full of sand toys
  #4 (permalink)
Old 03-08-2007, 02:17 AM
oh yea and since we are in the competition forum if you want it for racing id say go with a small shot of noz instead.
__________________
06 KTM 450SX
04 RMZ250
  #5 (permalink)
Old 03-08-2007, 10:29 PM
6L PWR's Avatar
Check my sig and you'll see I've already got the NOS. 100HP shot actually. Since the Stage II's were installed, I've got TONS of smoke and EGT's get very high, very quick. Looking for this mostly for running at the strip.
  #6 (permalink)
Old 03-08-2007, 11:14 PM
I see it now.. so how is your tranny running so far with all that work done? does it puke coolant at all with your arps? what are you hitting on the 1/4 mile if you dont mind me asking?
__________________
06 KTM 450SX
04 RMZ250
  #7 (permalink)
Old 03-09-2007, 07:12 PM
6L PWR's Avatar
No tranny problems at all. I do have an aftermarket Torque Converter as well.
It never did puke all that much coolant before. I started off at 2500 miles with an Edge Juice Platinum with Hot code and NOS. It ran a 13.8 like that.
Not only do I have the Studs, but I totally removed the EGR cooler and plugged it.
I haven't been to the track since my latest mods. Just finished them up in Dec. 06. Planning on hitting the track nexxt weekend. I have been up against a truck that consistently runs a 12.3 and I pulled away. Too freakin' kewel!! Dying for numbers!!
  #8 (permalink)
Old 03-10-2007, 10:32 PM
CSIPSD's Avatar
CSIPSD is gaining momentum as a positive member of FTE.
I have the Snows kit... It has worked fine for 2 years but there coustmer service sucks, there support after the sale sucks, and they want a small fortune for there injectors... Get the cooling mist kit, I have installed theres and it is 99% better then the Snows... Just look at there (snows) stage 3 kit and then at the cooling mist...
__________________
01 F-250 SC PSD,125k,16 Isspro Gauges,AFE-2,CCV Mod,IAH delete,map reg,Turbonetics BB turbo,6.0IC,GTS Hybrids,Studs, Forged Rods,Water injection,DP and Wildman Tunes,4" duals,Aero,6" tip's,100 axl tank,4" Revtek lift,37" TOYO MT's 467hp-1066tq
Joe AKA The Gauge *****
  #9 (permalink)
Old 04-22-2007, 01:06 AM
tiredlr is starting off with a positive reputation.
I run a real basic single stage system from Coolingmist. The service and tech help from David are excellent. Since I put my kit on they have added braided steel lines and new couplers/fittings for the lines, and also a very versatile variable controller that you can use both boost and EGT's to run the water.
My 6 gallon tank and pump are mounted in my tool box. I can use all 6 gallons when towing my towhauler in about 100 miles. Wanting to go to atleast to a dual nozzle setup if not a dual stage set up.
I notice the EGT's are reduced by about 150 degrees or so. Its kind of neat to watch them actaully dropping(digital gauge), and you know when the waters on!
__________________
2004 CC SHORT BED, 6.OL PSD K&N, SCT XCAL W/ATS CUSTOM TUNES , HOG 4" EXHAUST, WATER/METHANOL INJECTION,17X9 KMC CHROME ENDURO WHEELS, 33X12.50R17 PROCOMP A/T's
  #10 (permalink)
Old 05-01-2007, 06:06 PM
Firestarter116's Avatar
Firestarter116 is starting off with a positive reputation.
does either kit add much power? EGT'S not really a problem
  #11 (permalink)
Old 05-02-2007, 12:51 PM
CSIPSD's Avatar
About 40-60hp at 40% meth... But If your EGT's are not an issue, then add more fuel!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
