7.3 Oil Change Instructions?
Originally Posted by J.D
Izzy, The oil that I sucked out of the HPOP was darker than the pan oil, I cant explain whats going on. DaveWilliams probably hit the nail on the head. Probably this oil doesn't join the main stream as much.
///SNIP///
///SNIP///
Joe
2002 7.3L F250 XLT CrewCab ShortBed 2WD
Izzy, I'm probably the least person of knowledge when it comes to what motovates things on this engine. One would think that since it's a pump it would circulate the oil from within. So far my expertize is (if you can call it that) the oil changes, UVC harnesses, 2818 filter, GP Relay. My P/S 7.3 never really needed any help, so I never had to learn. I hope it's because of all the oil changes. Joe
So why would you guys change to Synthetic rather than Dino in the 7.3. I am pretty **** about maintanance myself and considered switching to Synthetic awhile back in my 6.0 but it was explained to me that unless you are going to extend the oil change intervals i.e. 7500 or 10000, or run a bypass filter and really extend them. It is simply just not worth the money.
I plan on changing the oil every 5k (or less)in the 7.3 just like I do in the 6.0...
This is very cheap insurance and peace of mind...
thanks,
JB
thanks,
JB
I have been accused of changing my oil to much, well that's just me. The truck has treated me right and I dont have any other repairs to spend the money on. I just converted from Dino to Sync, both Rotella. I was hesitant but did it anyhow because the oil needed to be changed. Unless it's me everything acts differant. The starts are better, the idle seems higher, smoother, quieter, and I'm sure the sync will protect better then dino, but that's just my opinion. My truck runs much better. I pull a heavy 5th Whl, 12k and need clean oil. I plan on changing the sync every 6k. I only have the stock oil filter system. I'm not saying that I wont have problems down the road with the oil, but now I love it.
Originally Posted by Fat Diesel
OMG you guys are ****. I just pour in all 4 gallons (some of it in the new filter) and call it good. 50+ oil changes later and no problems. I have checked the oil less than 5 times in the 8 years I've had the truck.
Are you suggesting to the OP that he just dump, *****-nilly, into his own crankcase (after putting some into the filter), 16-quarts of oil into a 15-quart capacity engine?.....Even knowing that not all of the previous oil is drained from the engine when you dump the previous oil?......
Good luck, and I hope that you have another trouble-free 8 years......
thanks,
JB
thanks,
JB
Joe
Originally Posted by Izzy351
I *do* plan on extending my changes a bit with the syn. I usually went 5k on my Ranger with the syn, but only 3k on dino. The other thing is that I just prefer & believe in syn lubricants. By the time I'm done, I'll have the whole thing swapped to syn (I also did that in my Ranger). Some folks believe the dino is fine (and obviously it is), but there are benefits to syn that I want to take advantage of. My truck only has 64k on it now (I put 4k on it less than 2 months), so it has whole lot of life left in it. The previous services were all written with a sharpie on the coolant tank, so I know it was well taken care of. I plan on keeping it in top shape so my daughter can drive it when she's old enough (she's 12 now). I will be using Blackstone to keep an eye on things, so there should be no problems extending the changes.
Joe
Joe
I have changed my oil at 5k on the 6.0 religiously (just did 60k service) and all Blackstone reports have come back good so far on dino.(will do the same for the 7.3)
Joe, I am assuming if I'm understanding correctly you have been doing the same on your 7.3... So I'm wondering if you've had OA's done and how they've turned out to this point.
JB
I switched to rotella synthetic last oil change for the easy starts in cold winter weather. I don't get to plug my truck in at night so it sits for 12 hours outside in the cold and i wanted to do everything i could to make sure it would start in the morning. Also i am going to try to see how extended oil change intervals work out. I am at 5000 miles right now and will be changing the oil and sending a sample to blackstone for a oa and see what they recommend.
The same for me. The most important for me was all the info I've been reading from 3-4 forums about some sort of MPG increases. Anything, I can do to help with that I will do. So far my truck starts better, runs smother, is quieter when warm. I wont know of any increases in MPG until later. I have use Rotella T since 99' and keep using it. I just went to the Rotella 5-40 Sync. and I am absolutely, 100% happy after only one week. But who knows, only time will tell. There are so many oils out there and they all have there own special hype. Who knows, after I do my own testing I will know. I will never (thats just me) let my oil run for extended periods (not thats there anything wrong with that), I'm just frigon to **** for that. 6k will my limits. That will be every 6 months.
I can understand and believe that synthetic definately has some advantages over dino. If you are going to extend the oil change intervals....As you said you were.
JB
JB
There are several other guys that have PSDs, so we're pretty even. A few have the HD Chevys, but none are diesel. They also get a good ration of s&#t, too...
Joe
guzzle92
99
02-26-2010 07:15 PM
Rancha9
06-22-2006 11:05 AM
