mystery oil for motor opinons
03-06-2007, 09:54 PM
on
Hi everybody,It sounds like one of my motors lifters is making noise.Does anybody have any opinions on the variuos mystery oils out there for tired motors.Thanks
03-06-2007, 10:01 PM
on
I have not any work real well. I did have some luck adding 2 qts of atf to the oil right before an oil change. I ran it for a little while to get it to heat up. The detergents in the ATF are stronger than oil. My bad lifter souded a little better. I watched my oil pressure gaudge real close. But in the end I had to pull the engine apart. Good luck. Jesse
03-06-2007, 10:08 PM
Check the oil and lube forum.
03-06-2007, 10:21 PM
on
you could try to adjust them as apposed to just sticking different oils in to quite it down..
03-06-2007, 11:08 PM
For what it is worth, I have used Lucas Oil Treatment in a '98 Dodge Ram 5.9 (Yes, I know I said "DODGE, but it does have a LOT of miles.) since the lifters started ticking at about 145,000. It now has 306,000 and finally starting to tick again. Probably going to be due for a rebuild at this point. I can speak for that treatment and that truck, but that is all.
03-06-2007, 11:13 PM
on
yeah that lucas works pretty good used it on an exploder that had a main knocking.. but why wouldnt you pull the valve covers and just do alittle ajustment for lifter tick??
03-06-2007, 11:25 PM
on
I dont think it has adjustable rocker arms and lifters. maybe check to see if one of the rocker bolts came loose.
03-07-2007, 02:59 AM
I used Risoline once on a 302, and it went away and never returned.
03-07-2007, 03:04 AM
I've used Lucas myself. It may help keep the oil pressure up a bit.
derek0525
09-24-2010 10:23 PM
a BigR HamR
07-09-2008 12:22 PM
lwpman
Oil & Lubrication
06-22-2004 12:23 AM
thelonerangerxlt
Oil & Lubrication
09-19-2002 04:58 PM
seymour
04-17-2002 01:52 AM
