Expedition window off track - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 03-06-2007, 10:02 PM
petercrabbe petercrabbe is offline
petercrabbe is starting off with a positive reputation.
Passenger window has come off track - window repair guy says his company wont allow him to use silicone on the window to reseat it (problem with the tabs) - and the adhesive they use wont stick to silicone which is on the window so only option is to replace whole window. This sounds like a scam to me. Question is -cant I just reseat and re silicone the window myself or is this a process that is too involved and should be done by a auto glass company?
Old 03-15-2007, 11:51 PM
Mountain Cat's Avatar
Mountain Cat Mountain Cat is offline
Mountain Cat is starting off with a positive reputation.
I had the driver's door window come out of the track. The window was leaning forward and would not go up or down. Took it to a local glass repair guy and had it fixed $60 later. Just had to leave the window in the up position for 24 hours until the adhesive set. The window did not need to be replaced and personally I would let a professional do it, but I'm sure it's not out of the realm of a DIY job.
--Brian
Old 03-17-2007, 11:12 AM
shadows4's Avatar
shadows4 shadows4 is offline
shadows4 is gaining momentum as a positive member of FTE.
I fixed my using Gorilla glue. Just make sure you clean old silicone off the window and clips are in same location.
Old 03-31-2007, 04:23 PM
KYExpy KYExpy is offline
KYExpy is starting off with a positive reputation.
Gorilla glue worked for me as well. Mine was the drivers side rear window. I cleaned it up real good. Gorilla glues it and then left the window up overnight. Been almost a year now with no problem.
Old 04-01-2007, 11:02 AM
andy_nominous andy_nominous is offline
andy_nominous is starting off with a positive reputation.
Silicone worked fine for me
I have had to reseat both front windows in my 97 Expy EB. I used clear silicone and have had no problems for 3 years thus far. I live in North Florida and park the vehicle outside year round so it sees extreme heat and moderately cold conditions.
I would recommend taking out the little black seats and thouroughly cleaning out the old silicone. Also make sure you thoroughly clean the window where it sits in the seats. Its tedious and time consuming but it makes a world of difference for the adhesion of the new silicone. Gorilla glue might work too, I've never used it but I would only use it if it stayed flexible. Anything that dries to hard will make it very difficult if you ever have to put new glass in.
Old 01-11-2010, 04:23 AM
bones58gdi bones58gdi is offline
bones58gdi is starting off with a positive reputation.
We have a 98 expedition. Drivers side. Window keeps coming off track. Tried Epoxy. I will give the Gorilla Glue a try. Getting the door off easy. Glue marks on glass locate the clips. Re-mark the with Sharpie. Removing the door panel on the 98 expedition was basic. The entire fix process is about 1 hour once you know how to remove the door panel. But if you can get it done like that other guy for $60 bucks - that's a deal.
Old 01-11-2010, 10:48 AM
dirtmonkey11's Avatar
dirtmonkey11 dirtmonkey11 is offline
dirtmonkey11 is starting off with a positive reputation.
The correct thing to use as a fix for the retainer clips is 3M panel bonding adhesive. Nothing else will hold it tight enough.
Old 01-11-2010, 12:46 PM
Thanks I will give that a try. It seems a little pricey at $40 but the sooner it gets done correctly the better. This will be my third attempt. It may have been too cold the last time I did and I got a poor cure on the epoxy.
Old 01-11-2010, 09:30 PM
Reefmonster Reefmonster is offline
Reefmonster is starting off with a positive reputation.
I did this exact same thing on the passenger side of the navi, it worked great for me, the tabs are easy enough to get out.
Old 09-15-2011, 11:25 AM
cdubauiv cdubauiv is offline
cdubauiv is starting off with a positive reputation.
thanks for all of the ideas. gorilla glue worked fine for me. let it dry for 3 days. rolled it up and down.., its works like new. thanks again.
Old 01-11-2014, 09:14 PM
Banker305 Banker305 is offline
Banker305 is starting off with a positive reputation.
I cant believe that modern tech would even attempt to believe that metal tightly squeezed on glass was the right way to secure a moving window.... wtf Ford????
Got a sluggish window? Kwikkordead 1999 - 2003 7.3L Power Stroke Diesel 31 01-05-2017 09:15 AM
Sun roof and back window issues zjohnson3 2009 - 2014 F150 2 07-18-2016 04:14 PM
Window off track geo422 Excursion - King of SUVs 2 12-15-2012 07:56 AM
Window jammed DanielC Aerostar 1 01-16-2011 02:51 AM
Squeaking canopy is driving me nuts! ajstephan Appearance & Dress-Up 1 03-21-2004 03:20 PM
Tags
2000, 2005, adhesive, back, expedition, feels, ford, glass, glue, half, offtrack, put, track, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
