Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-06-2007, 08:25 PM
RomerB2's Avatar
RomerB2 is gaining momentum as a positive member of FTE.
Hey there everyone.. 4.0 swap tricks?
What's up guys, I just thought I'd tell you guys you'll be seeing more of me in here again. It's been a while since I've been here, but I'm finally going to fix my BII by swapping in a 4.0 and some new rims and a new interior (cloth seats? haha, I'm a leather man). So other that that, I just wanted to say hi to a few familiar faces, and I'll see you on the boards!
BTW - If anybody has 4.0 swap tricks or anything, throw them in here if you would. I'm getting my 4.0 on Friday complete with all wiring, computer, and everything.
__________________
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-06-2007, 10:46 PM
kernel-panic's Avatar
kernel-panic is starting off with a positive reputation.
Copied and pasted from another forum I'm on, and no, I didn't do this write-up....
The easiest way to make a 4.0l plug and play on a B2/Ranger.
The Bronco must be an 89 or 90. You need to have the big white bulkhead plug on the firewall. I believe they started this in 89. I don't remember the 88 I cut up having this.
The donar 4.0L engine, must come from a 90-92 Ranger.
The bulkhead plug pinouts I believe are the same.
What you will need from the 4.0L ranger donar.
1. all engine harness. Including the distribution box and headlight harness, starter relay, and harnesses going to the ECU.
2. 4.0L engine and all accessories.
3. 4.0l Y-pipe.
4. Fuel line from engine to filter. (1990 B2's use the same fuel line from the filter to the connection for the fuel rail. Same connectors as the 4.0L so the fuel line is a plug in, on 90 B2 models only.)(89 models will have to splice the return line)
5. Purge valve from the 4.0L ranger. (for the charcoal canister)
6. ALL Battery connections also to include the ground.
7. Transmission, (Auto for Auto or manual for manual. If your keeping your trans then the FM146 will need the 4.0L clutch parts.) Master cyl is recommended, as the slave fittings at the end of the hose could be different.
From the 2.9L swap I did on the ranger and the 4.0L swap on BIV, these are the things I have noticed.
This is the easiest plug and play that I know of. All others will have wire splicing involved.
One other thing to note is that between the 90 model B2 and the 91 ranger they changed the interior plugs for the heater controls. Wire colors are the same however but the plugs have been switched around. Splicing may be needed here, inorder for the heater controls to work.
That is the Plug and play swap for the B2's.
This would have been the way the rumored 4.0L B2 would have been done. This will net you the most factory look ever. People will wonder if you have the factory 4.0L equipped B2.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
1995 Nissan D21 Hardbody 2.4L I-4 5-Spd 2WD
MSD, K&N air filter, Taylor wires, Pacesetter header & 2 1/2" exhaust
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #3 (permalink)
Old 03-07-2007, 05:14 PM
RomerB2's Avatar
That looks pretty good, I've been reading up on this a lot, and that seems to be the easiest way to make it sound, haha. The engine that I'm getting is from a 92 Explorer. What is the starter relay though? Does anybody know where that's at?
__________________
  #4 (permalink)
Old 03-07-2007, 08:16 PM
HappyJack has a good reputation on FTE.HappyJack has a good reputation on FTE.HappyJack has a good reputation on FTE.
The starter relay is near the battery. The + cable from the battery goes to one side of the relay. The starter cable goes to the other side. When you turn your ignition switch to the start possition it sends power to the relay. This closes the relay and sends power from the battery to the starter.
__________________
Happy "Lonesome Beaver" Jack
"Jr." All Grown Up
SSRNC Member #0
  #5 (permalink)
Old 03-07-2007, 09:35 PM
RomerB2's Avatar
Ohh ok, I know what that is and I was planning on getting that as well.
Question - Do the 4.0's have a standard type distributor? I've heard some mixed stories on these and their ignition type.. so I'm a bit confused.
__________________
  #6 (permalink)
Old 03-08-2007, 07:15 AM
Mine does not. It is a 94. There is a camshaft position sensor in the hole where the distributor would be.
__________________
"Jr." All Grown Up
SSRNC Member #0
  #7 (permalink)
Old 03-08-2007, 10:10 AM
I believe the "early" 4.0s and 3.0s had distributors, but in either '93 or '94, I forget which, they switched to the EDIS ignition... which is why most swaps usually are best with the '90-'92 4.0s -- unless you can pull the CPS and put a distributor in there... this I was unaware of, as far as the CPS unit being where the distributor would be... that makes me think and wonder if the 3.0s are the same, and what you can and can't do, etc.
__________________
  #8 (permalink)
Old 03-08-2007, 05:23 PM
RomerB2's Avatar
I've heard somewhere that you can swap the 2.9 distributor in there.. can anybody confirm this?
__________________
  #9 (permalink)
Old 05-15-2008, 03:29 PM
eveready77's Avatar
eveready77 is starting off with a positive reputation.
As far as I know or have read the 4.0 has never used a distributer. I had a '92 ranger with the 4.0 and it had the cam sensor distributer-less ignition. I have seen where people have thought about useing a dist. out of a 2.9 in a 4.0 but this would involve a good deal of wireing as the computers are different.
__________________
'07 Dodge Ram 2500 SLT, quad cab, 4x4, Cummins
'74 bronco UNCUT! 6 cyl and 3 on the tree (new project).
'73 F-250 custom 4x4 highboy, 360, np435/205
'89 BII XLT 4x4, 2.9l auto. 30x9.50 cooper st
  #10 (permalink)
Old 05-16-2008, 08:11 AM
Eddiec1564 is starting off with a positive reputation.
Does the 2.9L distributer actily fit into the 4.0L engine? Are the gears and oil pump shafts the same?
  #11 (permalink)
Old 05-16-2008, 11:56 AM
5.0B2 is starting off with a positive reputation.
My '91 Explorer had EDIS. I don't know of an Explorer that had a Distributor ingition.
__________________
1965 Falcon Ranchero hiPo 289 9"
1979 Lincoln Versailles 351W 4v
1984 BII 5.0FI 4R70W B/W 1356 d35 & 8.8/disks
1997 Explorer Sport 4.0 OHV
  #12 (permalink)
Old 06-04-2008, 01:46 PM
tnab1970 is starting off with a positive reputation.
check out therangerstation.com lots of links there for help, also have a technical library with lots of swap info.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
