AMD v/s Intel processors. Which do you like best? - Ford Truck Enthusiasts Forums
View Poll Results: AMD or Intel processor; Which do you like?
AMD! 31 52.54%
Intel! 19 32.20%
Other (what kind?) 0 0%
Don't matter as long as it runs? 9 15.25%
Voters: 59. You may not vote on this poll
Old 03-06-2007, 06:17 PM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS SCWIDVICIOUS is offline
SCWIDVICIOUS is gaining momentum as a positive member of FTE.
I like AMD personally. I have heard the Intel Core2 Duo 2 is quick too.
Old 03-06-2007, 06:39 PM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
I voted Intel because thatís all I have, but when Iím in the market I look at both before I decide. Theyíre always jockeying for position so I go with whatís better at the time, so far itís always been Intel.
Old 03-06-2007, 07:32 PM
NASA_Hokie NASA_Hokie is offline
NASA_Hokie is starting off with a positive reputation.
Right now, Intel. The Core 2 Duo runs circles around the AMD. AMD's quad core is going to be tough though.
Old 03-06-2007, 08:23 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
i've always ran intel
Old 03-06-2007, 08:28 PM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
I haven't run intel since the celeron 266 (aka celeron 400) I think this is the sixth or seventh cpu since then... all AMD.
Old 03-06-2007, 08:29 PM
Americanmadeford's Avatar
Americanmadeford Americanmadeford is offline
Americanmadeford is starting off with a positive reputation.
Who cares who has the fasest "super chip" on the market at the time? AMD offers better bang for your buck, hands down, undisputed.
Old 03-06-2007, 08:33 PM
arctic y block's Avatar
arctic y block arctic y block is online now
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
AMD Forever. ARHRR AHRRR
Old 03-06-2007, 08:39 PM
johntucker09's Avatar
johntucker09 johntucker09 is offline
johntucker09 is gaining momentum as a positive member of FTE.
most benchmarks show intel (Core 2) either running very very close or outperforming the amd (FXs and X2s)...i know in another post we were discussing RAID 0 and 1...so if it is performance you are going after, I defintely say go for the intel...and just to prove I am not an intel hack, i am not typing this post on an AMD or an Intel...I personally like the PowerPCs...
Old 03-06-2007, 09:21 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
Intel. They are always simple and straight forward to set up and overclock if that is your thing.
I have a Prescott 3.0 D0 that will run 4.2 with the right RAM. As it sits with 2x1gb Corsair XMS RAM, it can only do 3.75ish but with very little voltage.
But when you get right down to it, either work just fine and you can only tell the difference in benchmarks and in multi threading back when Intel had HT tech and AMD only had single core.
Mike
Old 03-06-2007, 10:06 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Over the years, since the first CPU AMD made, they have been pretty quick little buggers.
Generally, a 2:1 speed over Intel. As in, an AMD and an Intel of the same speed, the AMD would do twice as much in the same time.
For real production type stuff, I never use AMD, or haven't so far, anyway.
I recently bought a laptop with an AMD x64 dual-core, and at 1.6Ghz, it's at least as fast as my 3.0Ghz Intel desktop... and being a dual core vs. "hyperthread" CPU, it should really sing multithreading...
"Back in the day" I wouldn't suggest AMD, because I witnessed way too many glitches with certain things that should never have been an issue.
Today? I wouldn't be afraid of them.
Or not too much for home use, anyway.
PS: Don't get me wrong, I'm not downing AMD - so no flames please
Old 03-07-2007, 12:15 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
I've always had good luck with both. AMD actually promotes open source development (mainly in linux by supporting companies that opt to pre-install) where Intel tends to be more supportive of the Microsoft crap. So I vote for AMD. Chip for Chip the AMD runs coolers, uses less power, and often has a slower clock speed, yet it does the same amount of work or more than it's intel counterpart. The dual core Intel is a joke, AMD has plenty of Dual core chips out as well and they will run circles around the intels. The quad core chips should really make intel go "What the !?"...
Old 03-07-2007, 12:48 AM
SPL Tech SPL Tech is offline
SPL Tech is gaining momentum as a positive member of FTE.
Right now Intel is number one. The Core Two Duo is faster then any of AMD's processors. They are number one on the market at the moment. I have the Core Two Duo and it is not slow...
Old 03-07-2007, 01:04 AM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
I voted AMD. I dont agree with some of the corporate policies of Intel, which I will not get into.
As much as I hate to admit it, Intel has the faster processor right now, the C2D. They also have a quad core version of this, the QX6700. Before that, AMD's K8 was thoroughly faster than anything Intel had... Wait 'till K8L comes out though, AMD will have it again. It goes back and forth. I'm sure when AMD is back on the performance throne, Intel will cut prices. Same story played out over and over again.
I personally like to buy processors from their server line, namely the Opterons. More thorough testing usually equals better overclocking. Also, and you wont hear this elsewhere, when you buy a higher level Opteron, like 185 vs. 165, you not only get more multipliers, you're very likely to get a better stepping than the lower level processor.
Of course, AMD's been releasing new sockets every time someone sneezes, and that's getting kind of annoying.
Old 03-07-2007, 07:39 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger 00BlueOvalRanger is offline
00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation00BlueOvalRanger has a superb reputation
I've had good luck and bad luck with both Intel and AMD. I've also use the Cyrix (sp???) processors, in the past. (486 DX2-80. What a blazingly fast machine!?! )
As long as the machine is stable and will do what I need it to do. . . that is all that matters. (O.K., I lied. Price matters, too!)
My laptop is Intel. My desktop is AMD. Both do what I need them to do.
Old 03-07-2007, 09:05 AM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud of
Like I even know the difference!
Nuts and bolts and belts and gears I can talk about.
The invisible comings and goings of gajillions of electrons through nearly atomic-sized circuits is not something I care to know about in any depth.
If it do what I ask it to do, I am fine with it.
1964 F250 4X4 SHIFTER BOOTS Cactusjack01 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-11-2016 08:32 PM
86 F150 Header,Sparkplug help. 86 double fudge 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-15-2014 01:49 AM
Engine loses power horseshoer101 1999 to 2016 Super Duty 1 04-28-2014 06:13 PM
Can Someone Help me do a Car PC? GamerGirlAlice Oklahoma Chapter 4 03-12-2014 04:34 PM
OEM PARTS KDAVID1 6.0L Power Stroke Diesel 19 03-06-2014 07:59 PM
Tags
80x286, amd, cpu, intel, procesors, processors, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
