Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-06-2007, 03:06 PM
hoxiii's Avatar
hoxiii hoxiii is offline
Garage is empty, add now
hoxiii is gaining momentum as a positive member of FTE.
E85 timing curve?
Something I was wondering is what an e-85 timing curve looks like as compared to a gasoline curve. Would it be basically the same shape, just advanced more or would it be totally different from gasoline, like propane is?
I'm building a motor that would really like the 105 octane rating and even with the economy loss I'm still going to be money ahead of buying premium or race fuel. I already know what needs to happen with the carb and fuel system, timing is the only thing i'm still trying to figure out.
Justin
__________________
86 150 SuperCab Shortbed 4x4 conversion XLT Lariat, 300, 435
85 150 4x4 convert, 390 FE, NP435, 205, 9" TTB 44
R.I.P 8-26-07
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=161169&.jpg
  #2 (permalink)
Old 03-07-2007, 05:20 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Well, theoretically, you have a few factors to think about:
1. Compression ratio. Typically the higher the compression, the quicker the burn. Thus, less timing here.
2. "Squish" or "quench". This will accelerate the burn, thus requiring less timing.
3. Fuel burn speed. This is what you're going to want to be concerned about, in your application. I've heard that ethanol burns faster than gasoline, thus requiring less timing.
4. Octane. Ethanol has a high octane rating, so detonation is not an issue. Thus, we can advance the timing to where the motor likes it best.
What we need to consider is that 99.9% of the information on timing curves is based on regular medium to low compression gasoline engines "converted" to use ethanol. The reason these were advanced is that the motor was tuned around detonation on gasoline, and the use of ethanol allowed the timing curve to be brought back to optimal for the engine.
An efficient high compression engine like you're building will probably not like a lot of timing. In fact, I'd say a regular gasoline type curve would probably be optimal. At any rate, put it on a dyno and tune it right. I'm going to guess about 36 degrees total, with all the advance in at about 3000rpm. Of course that's a wild guess; I dont know what you're building!
  #3 (permalink)
Old 03-07-2007, 11:07 PM
hoxiii's Avatar
It's basically a stock rebuild on a '64 390 PI, but with a different cam. It's 10.5:1 and will make about 350hp by 5,000 rpm.
The point about people advancing the curve because the motor was originally desgined for gasoline is a good point that I hadn't considered. Thinking about it stock should get me pretty darn close. I'm not going to put the money into dyno tuning the motor because i don't have it, but i am going to track tune it which will give me a chance to figure it all out.
Justin
__________________
R.I.P 8-26-07
  #4 (permalink)
Old 03-07-2007, 11:29 PM
Keep in mind, that it probably wont ping even when over-advanced to the point of losing power. So you'll have to play with the timing to get it to where it produces the best power.
Also, 10.5:1 is still fairly "low compression" for E85.
  #5 (permalink)
Old 03-07-2007, 11:35 PM
hoxiii's Avatar
Yeah, but it's on the verge of too high for premium. If i ran a more aggressive cam to bleed some more compression off i could get it safely within the pump gas range, but aggressive isn't what i'm after.
And i was figuring it probably wouldn't ping when over advanced, that's why I'm going to track tune it. get it setup to make the fastest runs, plus it'll let me try a step rich and lean on the jetting.
Justin
__________________
R.I.P 8-26-07
Tags
390, 50, compression, curve, e85, engines, fe, ford, gasoline, high, low, motor, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
