wheels interchangeable? - Ford Truck Enthusiasts Forums
Old 03-06-2007, 12:17 PM
schefner schefner is offline
schefner is starting off with a positive reputation.
Anyone know if the wheels off of a 2001 f250 will fit an 86 f250?
Old 03-06-2007, 12:26 PM
wheelchick wheelchick is offline
wheelchick is gaining momentum as a positive member of FTE.
Sorry, they definitely will not fit. Ford changed their 8 lug bolt circles to metric in 1999 so here is the bolt circle guideline for
Ford F-250/350 single rear wheel:
1997-Back = 8-6.5" bolt circle
1999-up = 8-170MM bolt circle.
Ford F-350 Duallys as follows:
1999-2004 = 8-170MM bolt circle
2005-up = 8-200MM bolt circle
Heather
Old 03-06-2007, 12:29 PM
Thanks for the info Heather.
Old 03-06-2007, 12:33 PM
you're welcome
Old 03-06-2007, 03:49 PM
jcruth jcruth is offline
jcruth is starting off with a positive reputation.
[QUOTE=wheelchick]Sorry, they definitely will not fit. Ford changed their 8 lug bolt circles to metric in 1999 so here is the bolt circle guideline for
just curious???? 1998's?? they didnt have any wheels on them??
Old 03-06-2007, 04:08 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
ford did not market a F250 or F350 truck in 98. you either got one tagged as a 97, or a 99
Old 03-07-2007, 01:44 AM
WA1986F-250's Avatar
WA1986F-250 WA1986F-250 is offline
WA1986F-250 is starting off with a positive reputation.
Wow, learn something new everyday...
Old 03-07-2007, 07:30 AM
86fu50's Avatar
86fu50 86fu50 is offline
86fu50 is starting off with a positive reputation.
they only made gas F250s in 1998 (i think marked up to '99 light duty or something). but they use the same body as the new er F150 it looks kinda weird. My Dads co. has 2 of them.
Old 03-12-2007, 09:45 PM
Brimmstone Brimmstone is offline
Brimmstone is starting off with a positive reputation.
Okay I have one for the gurus here and this looks like the perfect thread for it. What would be needed to convert a single rear wheel to a dually. It seems to me all I would have to do is get a set of hubs off a dually and install them on my current sterling. I can get a set of dually hubs and rims for next to nothing from a yard I deal with. Any insight would be appreciated.
Old 03-12-2007, 11:26 PM
speedrdr speedrdr is offline
speedrdr is starting off with a positive reputation.
i'm thinking unless you've got a 250 that's got more clearance than mine at the springs, it just ain't gonna work without a heap of mods. thought the same thing on my '90 and took duelly rim and turned it backwards on the rear. unless it had some skinny rubber on it, there wasn't enough room for suspension movement. plus, the skinny rubber kinda defeats the purpose of a dual rear setup, don't it?
speedrdr
Old 03-13-2007, 12:45 AM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
Quote:
Pretty much requires getting the full-width axle from an F350 to do it right. Might as well get the bed while you're at it - otherwise you have to cut a huge chunk of sheetmetal off the outer skin on each side and install the fiberglass flares to accomodate the dual wheels - so they don't rub your wheelwell openings.
That's what was done to the second truck listed in my signature - rear axle and bed swapped in from an F350. Everything fits perfect with pretty much no modifications....
Old 03-13-2007, 12:50 AM
Well I already have the F-350 to begin with. It's a 1987 F-350 with a sterling rear axle. Did the duallies use a wider axle to start with? I can't seal a company making two different axles housings one for a single rear wheel app and one for a dually app.
Old 03-13-2007, 12:57 AM
don't know about ford, but chevy sure did. had a 3/4 ton with a single wheel 1-ton rear axle and suspension under it. !@%#$# thing rode like stink, too. that's why i got a ford now with a reasonable suspension under it.
speedrdr
Old 03-13-2007, 01:14 AM
I have two Suburbans with one ton axles rom the factory. I have run all ove the east coast with the 93 pulling one trailer or another to the point no one recognizes the truck unless it has a trailer which is bad because it's bright yellow. The other is a 92 which is becoming the traveling truck as it has 3.73 gears in it instead of 4.10s like the 93.
Old 03-13-2007, 10:26 PM
whitefordaward whitefordaward is offline
whitefordaward is starting off with a positive reputation.
Quote:
they are also a 7 lug bolt pattern they sold like crap.a freind of mine worked in fords marketing devision at that time.
Wheel sizes for 2016 F-250? hometheaterman 1999 to 2016 Super Duty 1 02-09-2017 09:07 AM
steering wheel/ horn js74f250 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-12-2016 04:31 PM
Wtb wheels for 1996 f250 green_95 WTB - Parts & other 0 11-09-2015 02:10 PM
2009 F250 wheel torque values sailorman3 1999 to 2016 Super Duty 6 04-24-2011 10:38 PM
F250 wheel covers? Gr8ride Brakes, Steering, Suspension, Tires, & Wheels 2 01-20-2007 08:39 PM
Tags
ford, interchangeable, rims
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
