anyone got pics of where the tac and speedo hook up for me?
i just realised today that my tac did not come on when i started the truck. the speedo has been sticky when its cold out for years now i figure its about time i look into this. sinse my return libne kit gets here tomarrow ill be under the hood anyways so does anyone have pics so i can easily locate them?
thanks you guys.
thanks you guys.
on my 91 the tack is on thr driver side IP cover and the speedo is on the back of the transfer case top of tail houseing driver side at slight angle has about a 3/8 diamiter cable leading in to it.the speedo gauge has probly lost it lubricant.pull the gauge from the dash pull out the cable and shoot a little whit litheum grease in the socket on the back of the gauge and shoot some tef-lube (comes in an arisol can) down the cable sleve.
seizure911- thats the ABS sensor thats on your axle.these speedos are mechanical on the back of the t-case or tranny tailhouseing.
Received 3,090 Likes
on
srisher
15
12-31-2014 02:10 PM
79F250isalive!
18
06-30-2014 08:11 AM
CameronA710
2004 - 2008 F150
04-23-2012 10:31 AM
