Normal Specs for MAF sensor in 5.4L Engine - Ford Truck Enthusiasts Forums
Old 03-06-2007, 10:40 AM
jrroth jrroth is offline
jrroth is starting off with a positive reputation.
What is the normal operating band for MAF for the 5.4L engine. The MAF sensor is reading from about 0.8 to 1.5 #/minute per OBD2 diagnostic software. I am currently trying to diagnose codes P0171 and P0174 in a 2002 E-150.
Thanks in advance
Old 03-06-2007, 08:22 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Not sure of the spec's right off, have you cleaned the MAF yet? Have you checked the PCV hose elbows for cracks/leaks?
Old 03-06-2007, 11:38 PM
JRROTH1 JRROTH1 is offline
JRROTH1 is starting off with a positive reputation.
No - I won't have time to really work on it until this weekend. I just wanted to see what the MAF sensor was doing prior to cleaning it. I figured if it was reading normal then I might consider leaving it alone and checking everything else first.
Old 03-16-2007, 11:18 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
At what RPMs? And how much go-pedal?
Old 03-19-2007, 11:33 AM
RPM are idle to about 2000 rpm under no load. Why go-pedal>
Jim R.
'04 F150 SuperCrew XLT 4x4 5.4L V8
'97 F150 SuperCab XLT 4x2 4.6L V8
Old 03-19-2007, 11:45 PM
LxMan1's Avatar
Because the voltage varies depending on how much air is being drawn thru it.
MAF sensor location 6t56 1999 to 2016 Super Duty 4 01-18-2012 07:45 PM
P0171 and P0174 2000Ford2000 Modular V8 (4.6L, 5.4L) 10 12-03-2011 08:08 PM
No power to MAF sensor. svn2002s 1997 - 2003 F150 2 06-08-2011 10:49 PM
Engine code P0174 Mike-11 1999 to 2016 Super Duty 3 01-10-2011 11:04 AM
MAF sensor replacement in 2000 super duty 5.4L cedarbend Modular V8 (4.6L, 5.4L) 6 03-15-2004 06:24 AM
Tags
2007, 54, 54l, e150, engine, f150, ford, maf, normal, reading, readings, sensor, specifications, specs, typical, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
