EGR Valve and the Dealer
Old 03-05-2007, 09:16 PM
UGA33's Avatar
UGA33
UGA33 is offline
When i take my truck in at 15k for the fuel filters to get changed, i want them to check my egr valve to see how gummed up it is. My question is will the dealership pull the egr valve just to to inspect and if need be clean it? And if they do what would they charge?
Old 03-05-2007, 10:14 PM
jim6liter's Avatar
jim6liter
jim6liter is offline
They may not pull it unless you complain about running troubles. If its gummed up causing troubles, it's warranty. Why not do the filters yourself and pull the EGR also? Not that difficult. Good luck!
Old 03-06-2007, 01:43 AM
hott-rodd's Avatar
hott-rodd
hott-rodd is offline
He's right filters from Internation ~40 vs 75+.
10 minutes to change.
The EGR is also very simple. I used a piece of hanger wire and the handle of my mini floor jack. Put a hook in one end , hold it to EGR to measure where you want the loop and then put a hook on the other end. remove the two screws gently turn the EGR with Large plyer. Hook the hanger end into the screw hole and pry up on the ALT. with handle thru wire loop. mine popped right out .
joe doyle
03-14-2009 09:16 PM
hacksaw830
03-09-2009 01:20 PM
mrmcdb2005
1983 - 2012 Ranger & B-Series
13
09-15-2004 09:04 PM
JCastellaw
27
01-20-2004 08:04 AM
JCastellaw
01-16-2004 11:35 AM
Quick Reply: EGR Valve and the Dealer
