Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #106 (permalink)
Old 06-21-2009, 03:06 AM
jdieselih jdieselih is offline
jdieselih is starting off with a positive reputation.
How do we determine what the "correct" cables are? It sure sounds like using the rigid linkages involves a huge pain in the rear end. What type of shifter would be best? I've heard of the stock shifter from spicer being used, also a floor mount auto tranny shifter and yesterday when I was at the junkyard I saw a shifter from a transfercase and wondered if that could work.
  #107 (permalink)
Old 06-21-2009, 02:01 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Use a PTO type cable, they are push/pull capable, what you use for shift lever could be as simple as a piece of flat bar or exotic as a gated shifter!
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #108 (permalink)
Old 06-21-2009, 11:03 PM
ghj ghj is offline
ghj is starting off with a positive reputation.
Quote:
Originally Posted by jdieselih View Post
That's great to hear. Is this behind a 7.3 IDI or a gas motor? Obviously behind a ZF5 either way. Where'd you hang it and what did you use for a shifter/shift linkages?
Behind a p-stroke. had to hang the box in front of the carrier brg. crossmember inorder to clear the fwd fuel tank. Front d-shaft is 22 inches-rear shaft is from a E350.
For shifter, I fabed a bracket that uses 2 shift levers from a WWII Jeep. I ran 1/2 inch rods to the tranny. With the two shifters it works great, since there is an interlock in the brownie that prevents any screw-up in shifting.
Only real problem I had was a leak in the input yoke and that was solved with a speedy sleece kit.
  #109 (permalink)
Old 06-22-2009, 02:27 AM
Hey I really want to use just one stick for the brownie if I can help it. I had always wondered if it was possible or not.
  #110 (permalink)
Old 06-22-2009, 02:34 AM
b-uno's Avatar
b-uno b-uno is online now
b-uno is gaining momentum as a positive member of FTE.
heres mine
__________________
"LOOK AR ME!!!"
  #111 (permalink)
Old 06-22-2009, 11:32 PM
Yeah, I can't read the tag....which 5831 is it? What are your plans for it? Sounds like you have a cool fleet? What diesels are in those conversions...the 75 and the Bronco?
  #112 (permalink)
Old 06-23-2009, 01:57 AM
bghnkinf250 bghnkinf250 is offline
1986 Ford F-250
bghnkinf250 is gaining momentum as a positive member of FTE.
Is that a parking brake on the rear?
I was curious if anyone knows the number for the seals for the shift rails on a 5831? I just got mine up and running and I love it, but I have fliud leaking from the D / OD rail. It is also a little pitted, which I will clean up while I am trying to replace the seal. If I need to, does anyone know where I can get another rail?
  #113 (permalink)
Old 06-23-2009, 02:39 AM
Would that be a gasket or a proper seal? A friend of mine on another Ford site just installed a 5831b in his f350. He said the seals and bearings and all are available at just about any auto parts house. I haven't checked for myself yet. He also said the gaskets except for the PTO port gasket are NLA and you just use anaerobic gasket maker there instead. If its a proper seal I'm sure I could get part #s from him for you. I can't be sure but if you have a hard time finding parts you might try Adlemans truck parts in Chicago. At least they still know what the heck these things are, sometimes even have a take out or two laying around.
  #114 (permalink)
Old 06-23-2009, 03:37 PM
1986 Ford F-250
I was looking for the seals for the shift rails, that would be great if you could ask for the numbers. I hate to ask, but would be too much to ask if I asked for the numbers of all the seals and bearings? I can not find any information on part numbers, and would like to start collecting some of them. If it is too much, then the shift rail seals would be a great start for me.
Thank you,
Nick
  #115 (permalink)
Old 06-23-2009, 04:08 PM
I PM'ed him, we'll see what I hear back. I'm eagerly waiting to get one of these boxes behind my T18, but I have to sell my Doug Nash box before I can spend the money...
  #116 (permalink)
Old 07-01-2009, 09:45 PM
davelance01 davelance01 is offline
davelance01 is starting off with a positive reputation.
Any old truckers reading this can probably remember the old double over transmissions. These transmissions were generally 13 speed road rangers, usually used by heavy haulers, but, what they would do is change the shifting pattern around so instead of your typical h pattern where you would start out in 1st down to 2nd then up and over to third you would go from 2nd and up and down to third then up to 4th with the same pattern on the high side. It had something to do with swapping gears around because they started with a standard 13 speed. I remember when I used to run back and fourth to Boston with one when I was running 55 mph and I was in 7th OD which left me with 8th direct and OD left, this truck had no problem doing triple digits at 1800 rpm. Just another angle on the subject.
  #117 (permalink)
Old 07-01-2009, 10:41 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
Redneck Has Been
rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE.
The RTOO's had .62 in the top gear.It allowed a trucker to run a lower rear end gear and still have a good road speed and some good splits
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #118 (permalink)
Old 07-09-2009, 11:01 PM
I have yet to hear back from Robert on those part #s. I may soon be in the same boat though. It looks as though I have a buyer for the Doug Nash box, and if so, that money will be parlayed into a brownie box someone is generously sitting on for me. probably reseal the thing before I stick it in the truck but you never can tell I might just roll the dice if it's tight.
  #119 (permalink)
Old 07-14-2009, 06:08 AM
1986 Ford F-250
You are probably better resealing it first, I rolled the dice, and am leaking out the seals now.....
__________________
"A man does what he must - in spite of personal consequences, in spite of obstacles and dangers and pressures - and that is the basis of all human morality."
  #120 (permalink)
Old 07-14-2009, 03:55 PM
b-uno's Avatar
well i opened my brownie box the other day after i moved it around, and the thing was completely full of WATER!! i know this isnt what is supposed to be in there.. but there wasent that much rust inside.. so i sprayed it full of pb blaster.. and turned it over by hand.. smooth as silk.. so i got both pto covers off and its air drying, when i get around to installing it im going to run it for a a tank of fuel or so then change the oil again.
Ray
__________________
"LOOK AR ME!!!"
Tags
5831 , 6bt , 715 , 7231 , aux , brownie , cummins , gear , shift , size , spicer , spline , swap , t98 , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
