Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #91 (permalink)
Old 06-04-2009, 04:50 PM
two-stick two-stick is offline
two-stick is starting off with a positive reputation.
Quote:
Originally Posted by acheda View Post
two-stick,
I had not up-loaded pics to my albums in a long time and found that I also could not add them to either an old album or a newly-created album. I am on a Mac and do not think I am doing anything wrong. I used a photohost and linked pics successfully in another thread. If anyone knows what is going on, I have no problem with posting help in this thread.
P.S.: One thought is that there are now limits on gallery size and maybe we are over the limit. I do not get an error message -- just small "?" icons.
I finally uploaded pictures into 7231-2.
Used Microsoft Picture Manager in Office to re-size the pictures.
Will have to go back and add captions.
  #92 (permalink)
Old 06-04-2009, 10:52 PM
jdieselih jdieselih is offline
jdieselih is starting off with a positive reputation.
Well thanks for the warning.. I had always heard good things about the 5531 and 5831 in light truck applications anyway. Also had heard you can get seals and wear sleeves and such pretty easily. The 7000 series sounds like it may be a bit more desirable but arent they much bigger and heavier? We're already pushing our luck with the 5531 or 5831 in an F250.
  #93 (permalink)
Old 06-05-2009, 09:08 AM
Quote:
Had no problem with seals with my 7231.
Took the old seal to establish the seal style along with i.d. and o.d. measurements.
I didn't go to an auto parts store but to a place that sold big truck parts.
I've never had a 5000 series but have read and heard from truck transmission guys that the 5000 series are not a first choice due to lack of parts and their lack of strength.
Don't know size and weight of the 5000 series but, 5000 oil capacity is 4 pints.
The 6000 and 7000 series is 8 pints and the 8000 series is 12 pints. You can see from the pictures in my album 7231-2 that the 7000 series is not a bad fit in an F series.
A bit challenging but not a bad fit. I was looking for a 5000 series until I starting discussing it with truck transmission people and then relaized a 7000 would be a harder installation but would generate less maintenance headaches. Check out my album 7231-1 for 7231-A/B/C/D ratios, specs and my installation notes. Also, I easily located a 7231 that had the ratios I wanted, 7231-B, 1.24/1.00/.86
  #94 (permalink)
Old 06-05-2009, 11:19 AM
Yeah that was very nicely done, neat install. Do you recall how long and heavy your 7231 is? It seems to fit nicely where you put it.
  #95 (permalink)
Old 06-05-2009, 03:32 PM
230 Lbs and 23-inches over companion flanges.
  #96 (permalink)
Old 06-06-2009, 05:55 PM
230 lbs and 23 inches? Oh wow! I've still heard more good than bad on the 5831. We have a member over at another web site that just installed one and is thrilled with it. He threw in all new seals and wear sleeves, used anaerobic gasket maker to replace the NLA gaskets and just generally cleaned the box up real good. I really don't want something bigger than a 5000 series box that's already heavier than my main box. So how about it F6 guy? Do you still have your 5831? What version is it and might you still part with it?
  #97 (permalink)
Old 06-08-2009, 12:39 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
Well the tag is missing but I believe it to be the straight up 5831 as it has a 2:1 under 1:1 and .64:1 over drive. If you are intrested PM me and we will go from there.
  #98 (permalink)
Old 06-08-2009, 02:16 PM
Like to see pictures of the finished installation.
My origional cross-members had to be modified as I didn't leave enough room for driveline symmetry adjustment.
Had vibration issues until I spent the time to get it right.
That 5831 .64 overdrive sounds good.
  #99 (permalink)
Old 06-08-2009, 06:39 PM
I couldn't figure out about PMs but I left you my contact info in one of your profile messages. Would love to hash out a deal.
  #100 (permalink)
Old 06-09-2009, 04:20 PM
Whoops sorry its .73 OD
  #101 (permalink)
Old 06-09-2009, 10:33 PM
Yeah man, I thought it was 2.00:1, 1:1, .73:1 that's just what I need. Thanks I returned your email. Thanks.
  #102 (permalink)
Old 06-13-2009, 05:09 AM
What are the pros and cons of using shift cables versus shift linkages on one of these brownie boxes? Which is easier to set up correctly? Which is cheaper? What's more likely to fold without warning when I'm a long way from home.... etc Thanks guys.
  #103 (permalink)
Old 06-20-2009, 02:08 AM
ghj ghj is offline
ghj is starting off with a positive reputation.
Finally did it!
Rebuilt my 5531 Spicer and installed it last week. So far so good? 5th gear with brownie in OD runs 1450 at 70 MPH. In 4th with Brownie in OD it is better than with out Brownie and using 5th gear previously. No lack of power in double overdrive especially at 75 mph.
I don`t know how the MPG`s will figure. Planning on a 6000 mile trip next week, so I guess I`ll find out.
Truck is 95 F350 SC ,SRW, 5 speed and 3.55 gears, lightly modified with 218,000 on the clock.
WISH ME LUCK
  #104 (permalink)
Old 06-20-2009, 05:41 AM
That's great to hear. Is this behind a 7.3 IDI or a gas motor? Obviously behind a ZF5 either way. Where'd you hang it and what did you use for a shifter/shift linkages?
  #105 (permalink)
Old 06-20-2009, 10:08 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is online now
Redneck Has Been
rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE.
Actually if you use the correct cable snd a decent shifter there is no downside.The upside is the ease of hookup not using rigid linkage
Some crane carriers used cable linkage on the aux trans
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
Tags
5831 , 6bt , 715 , 7231 , aux , brownie , cummins , gear , shift , size , spicer , spline , swap , t98 , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
