Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-05-2007, 05:54 PM
89tankinhalfton is starting off with a positive reputation.
what the hell is wrong with my clutch?
i have a 1989 ford f-150 and as i was driving home last night i pushed the clutch in and then it wouldnt come out i had to drive all the way home in third gear. the clutch pedal will now not pop back out unless it is pulled by hand please help i have to go to school tommorow but would mind pulling an all nighter
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2007, 06:24 PM
FrontRangeF150's Avatar
FrontRangeF150 is starting off with a positive reputation.
The same thing just happened to me, it is most likely the Slave cylinder for the clutch. Check to see if you have fluid in the bell housing. Mine went bad enough that the fluid was leaking out of the bell housing. If this is the case you will have to drop the tranny and replace the slave cylinder. While you are in there you might as well do the throw-out bearing, clutch, and pressure plate. It's also a good idea to get your flywheel refinished and replace the rear main while your in there. I dropped the transfer case and driveline (4x4 so front and rear) last night and will be dropping the tranny tonight and hopefully have it all together by the end of the night.
  #3 (permalink)
Old 03-05-2007, 07:11 PM
RollinHi95 is starting off with a positive reputation.
same thing happened to me. slave cylinder for sure.
__________________
1993 F-250 HD
351W ZF 5-speed
Warn Classic Winch Bumper
8000Xi winch
35x12.50 Pro Comp All Terrains
16x10 US Wheel Black Daytona's
3" body lift and 1" blocks in front
K&N FIPK, Hooker Comp LT's, 2 1/4 dual exhaust
Hooker Aerochamber Mufflers, o/r H-pipe, 4" tips
  #4 (permalink)
Old 03-05-2007, 07:51 PM
thanks for the help do you know how much it costs?
  #5 (permalink)
Old 03-05-2007, 07:56 PM
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Depends in your area look around for and find the cheapest one if you dont wanna spend a lot doing it yourself saves $$$ good luck man
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
2006 F150 XLT Supercrew 5.5ft box XTR 5.4l 4R75E 3.73 LS 4x4
  #6 (permalink)
Old 03-05-2007, 09:08 PM
The clutch Kit and the slave cost me about $250
  #7 (permalink)
Old 03-05-2007, 09:09 PM
thanks yall
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
