engine block heater? - Ford Truck Enthusiasts Forums
Old 03-05-2007, 04:05 PM
Robber80 Robber80 is offline
Robber80 is starting off with a positive reputation.
I just bought a 2007 f350 with a 6.0. i can't find the engine block heater cord?? I looked in the owners manual and it says "If Equiped"???? I thought all diesels would have a engine block heater. so i went online and built a 2007 superduty on fords website. there is now option for a engine block heater??? so what gives? do i have one or no?
Old 03-05-2007, 04:07 PM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
If you have one it will be right beside the left fog light on the front of the truck
Old 03-05-2007, 04:17 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Like UGA said it should be up by the passenger side tow hook/fog light inside the bumper. It will have a cover on it so don't just look for the three prong plug (someone else on here didn't notice it at first because of the cover). Only the trucks that were originally shipped to what Ford thought were "cold" states got them, unless it was ordered as an option. If you don't have the cord you can buy one from Ford, International, or from many online sources. Ford is by far the most overpriced though.
Old 03-05-2007, 04:21 PM
well thats why i'm asking, because i intalled a plow and had to remove the bumper to do it. there was deffenetly no cordes anywhere to be seen left or right. so is the engine block heater there, but no cord? or do i have to actually get a engine block heater itself?
Lonewolftx's Avatar
Lonewolftx Lonewolftx is offline
Lonewolftx is gaining momentum as a positive member of FTE.Lonewolftx is gaining momentum as a positive member of FTE.
Wink Try here . . .
Here is where you hook up the factory plug/chord to the heater core from inside the engine block. Passengers side above the starter. Loof for the orange, extension cord like piece coming from out of the block.
Old 03-05-2007, 04:36 PM
catmaninil catmaninil is offline
catmaninil is starting off with a positive reputation.
i have a 07 f250 crew cab 8 foot bed 6.0 i also searched for the cord well i found theblock heater in the block but no cord attached to it if ya look at the sideof the block near the starter you willsee the freeze plug with the block heater in it but no cord attached the cheap *******s
Old 03-05-2007, 04:38 PM
Yep the heater is already installed in the engine you just need the cord. A buddy of mine here at work says that any International heater cord with the two female contacts and the ground on the outside edge will work. He said there should be one for around $10. I bought mine before I talked to him, and got the part number I found on here and it ran me $40. My cord has a ground fault switch in it which I am sure bumped up the cost a bit.
Old 03-05-2007, 07:59 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
I would think that a vehicle bought in Vermont WOULD have the cord. It def. gets cold enough there! Isn't VT one of the 'cold' states that's supposed to have the cord installed?
Old 03-05-2007, 08:23 PM
NorCalBusa NorCalBusa is offline
NorCalBusa is starting off with a positive reputation.
I picked up my F250 diesel last week- same deal; no cord. Thanks to this board, I found the already installed heater element and simply ordered a power cord today. Access is super easy, as will routing the wires be. I'm taking mine to a timer and tying in a Battery Tender- then taking the 110v aft where I'll be hard wiring an outlet in/near the rear bumper with a recessed plug. Whenever it's plugged in; the Battery Tender turns on (keeping the batteries topped off and warm) and the block heater will be on a timer, going long before I wake up.
Old 03-06-2007, 07:09 AM
well thats very good news. it was -12 today so i would have liked it. truck still strats fine. i just want it to start with less wear on the motor. thank you all for the info!!
Old 03-06-2007, 07:54 AM
Lonewolftx's Avatar
Lightbulb
Sure, you are welcome. How about some rep points?
Old 03-06-2007, 02:21 PM
should i call ford and tell them to give me a cord for free? especially since i live in a cold state? they want about $80 for it and they can get it for tomorrow or the next day. i really don't have time to go make or search for cheaper, its gunna be cold for the next few days so i want it in and heating. what do you think?
Old 03-06-2007, 02:37 PM
Good luck with telling Ford what they're going to do or not...I'd just buy the silly cable and save the arm wrestling for when ya really need it.
Old 03-06-2007, 02:40 PM
IIRC, going to powerstrokeparts.com: it was $50. Check that url though, I'm on my Blackberry so I'm not sure, it did come off the FTE site/search.
Old 03-06-2007, 02:53 PM
nubeee1's Avatar
nubeee1 nubeee1 is offline
nubeee1 is a splendid one to beholdnubeee1 is a splendid one to beholdnubeee1 is a splendid one to beholdnubeee1 is a splendid one to beholdnubeee1 is a splendid one to beholdnubeee1 is a splendid one to behold
That's weird, I live in vegas, and it came with the truck, installed....go figure
Need engine block heater advice 2gumby2 2015+ F150 11 04-06-2016 11:30 AM
Help with after market Engine block heaters please blueeyedfordguy General Diesel Discussion 9 12-16-2013 02:22 PM
Block heaters Rusty_Old_F250 1973 - 1979 F-100 & Larger F-Series Trucks 23 11-26-2011 01:02 PM
2002 Ford F250 Heater Block firefightermoses 1999 to 2016 Super Duty 6 02-04-2011 03:02 PM
F250 Engine Block Heater mudslide 1999 to 2016 Super Duty 5 02-25-2009 09:19 AM
Tags
150, 2006, 60, block, cord, diesel, engine, f250, ford, heater, heaters, location, powerstroke, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
