Intake and Header Install on 85 I-6 Pics - Not 56k friendly...
Got a deal on an offy intake and a set of split headers... Not sure what brand the headers are, but they clear everything perfectly (looks like it will be a P.I.T.A to change the starter now though) The intake is an Offenhauser "C" series single plane aluminum intake.
Here is a shot of the new stuff, they were used parts and the headers were rusted almost as bad as my Bronco's rear quarters... Anyway, I had them sand blasted and I sprayed them with some heat resistant flat black paint... I know I know... cheap, but they're just gonna get mud on them so what the heck...
Here was my engine before... Motorcraft 2bbl on an adapter plate with the stock cast iron intake and exhaust manifolds.
30 mins. later that and that ugly P.O.S. is gone... I love straight sixes, everything is so much easier to get to.
Look at how much more constricted the flow is here compared to the single plane offy intake in the first picture...
This bracket did something at some point... maybe A/C or the smog/air pump??? Not sure, this isn't the original motor and my Bronco never had A/C to start with, but I know all I need is the bottom end of the bracket to hold the alternator... the top part is right in the way of the front header tube...
I picked up a throttle cable linkage I thought I could make work. It's an off the shelf part for GM's... I just modified it to work with my stock throttle cable.
Finished Assembly
Here are a couple of shots of it on the carb, it seems to work fine but the stock cable doesn't have enough travel to achieve actual WOT. Not sure how to fix that really... even with an aftermarket cable I'm not sure I have enough travel at the pedal. It does travel enough that the secondaries open though and it runs great so I probably won't even mess with it. It's a 600 cfm Edlebrock Performer with elec. choke and vaccuum secondaries. I added the spring loaded seats and lowered the float level... so far so good, but there are a couple of places I wan't to try with it first to see if I have any stalling problems before I sign off on it's reliability. It sure is purdy though... so shinny and clean, not real sure what it's even doing on my motor?
PCV system hook up was easy... I ran the line from the pcv valve to the vaccum connection for it on the front of the carb. The vent hose on the front of the valve cover is just hanging out there right now but I have the fitting to hook it to the bottom of the breather... I just haven't connected it yet.
I also did the duraspark II swap when I swapped everything else out, I haven't had any timing advance since the original feedback carb crapped out on me. It was an easy swap on my 85... plugs were already there I just disconnected the dizzy and module that were there and plugged in the DS-II unit and ran a hose from the carb down to the advance. Took all of 15 mins. I think.
Finished Assembly
Originally Posted by PatsPOS
Pretty durn cool....might wanna try drilling another hole in the throttle arm closer to the shaft to solve your WOT issue, if you choose to fix it in the future.
Pat
Pat
I think the part I like about this setup the most is how much it de-cluttered the engine. All the wires running between the feedback carb and the dizzy are gone now, about half a dozen plugs and wires that went to the smog stuff is all gone. No EGR, heck I don't even need the vaccuum tree anymore, it's all plugged off. I'll probably remove it and just plug the hole.
Hey, no problem...even I come up with a simple solution every once in a while. I'm usually guilty of overengineering things myself, so it's a good thing I have my brother to keep me down to earth.
Kinda jealous that you're able to lose your smog equipment. We got emissions testing in the county I live in two years ago (just gotta pass a visual inspection...the stuff doesn't actually have to WORK!), right after I made a small y-pipe to replace my front cat after it broke.
Pat
Pat
Pat
Pat
acelogik - I'm not required to run smog equip on that vehicle here in OK, so it was a non-issue. The only vac lines I kept was the brake booster, vac advance, and PCV valve, all of which run off the carb. I just plugged off the holes in the intake where the vac tree screwed in. Most of the misc. vac system and wiring left when I dumped the stock manifold and carb and when I did the DS2 swap. There's not much left now, just what is necessary.
redneckmechanix - That's a whole lot of carb for the six... when you re-built did you open it up to handle that kind of cfm... atleast a mild port on the head? I had to do some work on mine just to get it to handle the 600 cfm I have. I added an excel higher voltage coil, gapped out the plugs a bit more, and bumped the timing to about 12* btdc. Otherwise it black smoked bad under load. It seems to run good now, but if I had it to do again I would have used a little smaller carb. The cheapest route on your headers would be to use stock headers off of a late model EFI 4.9L. They're a split manifold config so you can run dual exhaust right from the motor. They don't flow like the long tube headers I have, but they're not too bad really. Great thing is they use stock manifold gaskets and you can pick them up at most salvage yards fairly cheap.
AbandonedBronco
157
01-11-2018 04:34 PM
ranger429
236
01-01-2016 06:50 AM
AbandonedBronco
1978 - 1996 Big Bronco
17
10-27-2015 07:58 PM
AbandonedBronco
Vehicles for Sale
10-24-2015 10:47 AM
