4 wheel drive quit - Ford Truck Enthusiasts Forums
4 wheel drive quit
Old 03-05-2007, 01:11 PM
guanabeachhouse guanabeachhouse is offline
guanabeachhouse is starting off with a positive reputation.
4 wheel drive quit
Hello all!
My 1998 V8 5.6l F150 4 wheel drive will not engage. I move the switch and hear a and electronic click like it is engaging but no go. It was working fine and after sitting in the driveway it stopped, in other words no grinding or trama to it. When I put it in low 4, the transmissions shifts into low but no 4 wheel drive. Where do I start with this one?
Thanks in advance.
Old 03-05-2007, 01:23 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
You probably have a cracked ruber vacum hose that goes to the front diff. Your Transfer case sounds like its engaging low range and 4x4 but the front axle isnt. I would start there. Some others on here will probably have some good ideas on how to track down the leak
Old 03-05-2007, 01:26 PM
Thanks for the reply
I did replace the starter recently. Is there a vacume hose by the starter I could have puctured or removed?
Old 03-05-2007, 06:03 PM
Im not sure where they route the vacume lines but it would be in that general vacinity i would a assume because i heard of a guy haveing his battery leak and the acid dripping ate his vacume lines.... but im not sure exactly where they come from.
Old 03-17-2007, 12:29 PM
bigredneck47240's Avatar
bigredneck47240 bigredneck47240 is offline
bigredneck47240 is starting off with a positive reputation.
that sounds like your problem a leaking vaccum hose it happened to me to
Old 03-17-2007, 01:39 PM
Galveston Yankee's Avatar
Galveston Yankee Galveston Yankee is offline
Galveston Yankee is starting off with a positive reputation.
If it's the same setup as the '02, you have vacuum control connections on the firewall on the right hand side behind the battery. I had to replace two vacuum hose harnesses. One that runs up from the transfer case to the control and one from the control to another set of hoses under the battery. Also had to replace one control unit (i don't know what it's really called).
Parts cost about $145 through the stealership. You could get hoses and run it all piecing it out. I found it easier to replace the whole harness.
It's only a two beer job if you take your time.
GY
If you send me your email address in a PM, I'll take a couple of pics and show you what I had to replace.
Old 03-17-2007, 05:37 PM
gavinhaslam's Avatar
gavinhaslam gavinhaslam is offline
gavinhaslam is starting off with a positive reputation.
What's the definitive way to test if the 4x4 functionality is working on these babies? Jack them up at all corners ? Rolling ROad?
I have the same scenario as yours I think but I'm not entirely sure whether 4WD is working or not...
Thanks
Gav.
Expy 5.4L XLT 4x4.
Quote:
Originally Posted by guanabeachhouse
Hello all!
Thanks in advance.
Old 06-10-2007, 03:25 PM
98f1504x4 98f1504x4 is offline
98f1504x4 is starting off with a positive reputation.
i have a 98 f150 and it is doing the exact same thing. if u got yours working would u mind telling me what you did to get urs working if u did get it working
Old 06-10-2007, 06:05 PM
No Go
I still do not have a solution. I will have to take it tothe dealer and have them go through and diagnose the problem
Old 06-10-2007, 06:27 PM
nobow nobow is offline
nobow is starting off with a positive reputation.
try looking at the ground switch on the transfer case.. I had to change mine looks like a oil pressure switch, I beleive it has one red wire going to it they go bad quite often. they are about 25-35 dollars
Old 06-11-2007, 09:14 AM
4wd
I will try that...
I just want to verify symptoms, All seems to work, it will switch the transmission into low, 4wd light goes on just no 4wd. I will check to see if i have to wire connected. thanks
Old 06-11-2007, 12:27 PM
tim.moman tim.moman is offline
tim.moman is starting off with a positive reputation.
You can do some verification with a driveway test with the right front off the ground.
place in 4wd. leave in park. You must start the truck to activate the vacuum.
Turn the driveshaft by hand.
Front driveshaft will not turn(engaged). TCase is working.
Turn the r-front tire by hand. if the driveshaft turns then the tcase is not engaging. If the driveshaft does not then the vacuum is not engauging the couple of the r-front to the diff.
Pull the hoses from the vacuum pot on the front axle. Then and have someone start the truck and switch from 2wd to 4wd while you listen and feel for the vacuum to change from one line to the other. If there is vacuum then look for the actuator to move when hooked back up.
A control issue like nobow mentioned might disable any of this from happening. but hopefully it will help from a mechanical view.
Old 06-13-2007, 09:53 AM
burninfordrubber burninfordrubber is offline
burninfordrubber is starting off with a positive reputation.
Vac Sylenoid, you should have two of them one is for enguage and one is for disenguage located behinde battery on fire wall try checking those out...
Old 06-13-2007, 02:29 PM
broncobilly1989 broncobilly1989 is offline
broncobilly1989 is starting off with a positive reputation.
My 99 LD F250 had the same problem. I found out after I sheered a ball joint trying to power my way up a hill in "4 wheel drive". I was in 2, cause I had a dry rotted vacuum line. The hard plastic lines crack on you, as the trucks are now 8 or 9 years old. Take the battery out, remove the battery tray. You will see a black box that attaches to the battery tray with vacuum lines coming out of it. Trace those lines and you will find all of the vacuum hoses you need to look at to fix your problem. After sheering my balljoint, I replace those, as well as all of the front suspension(didn't want it to happen again) and then I had to have my fender, hood and door fixed as the tire pushed the body where it didn't belong.
4WD Not Engaging tonythepony 1997 - 2003 F150 9 11-25-2014 10:46 PM
4Wheel Drive not engaging Caretaker 1999 to 2016 Super Duty 10 12-13-2011 09:18 PM
4x4 questions on 87 BII dmkolb Bronco II 2 04-25-2006 12:24 PM
1992 f-150 4-Low RyanJake 1987 - 1996 F150 & Larger F-Series Trucks 6 02-03-2005 07:09 PM
4X4 wont engage.. Help!! HawkinNY Offroad & 4x4 7 12-28-2002 01:13 PM
Tags
drive, f150, ford, hear, quit, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
