Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-05-2007, 12:30 PM
HFMotorsports is starting off with a positive reputation.
Swapping FE Manifolds
This is a total FE noob question. I known to change manifolds I need to pull the rocker arms and pushrods, but how difficult is it to reinstall/reset them after the new mani is on? I've spent a lot of time working on SOHC/DOHC engines, but I've never worked on an engine with pushrods. How much of a PITA am I in for? Trying to see if I need to plan an evening or a weekend for the swap.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2007, 01:25 PM
hiball3985 is starting off with a positive reputation.
not a major operation, remove distributor,remove rocker arms and pushrods..keeping the pushrods in order so they go back in the same place is the key, then you won't have to deal with preload problems
__________________
JIM
1960 F100 Panel
223 3 spd overdrive
1966 F250
390 4 spd
  #3 (permalink)
Old 03-06-2007, 01:04 PM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
Exactly, everything else being the same, just remove the rocker arms/shafts (the right way), keep the pushrods in order, and reassemble in the opposite direction
When I say "right way" to remove the rocker shafts, I mean break all the bolts loose working from the outside in, and go 1/2 turn off every bolt, another 1/2 turn, etc. etc. until they come fully loose. Others here will probably have a slightly different way to get them off, but 1/2 turn increments might take a while, but it's better than bending/cracking a shaft.
Also, put the right and left shafts back on the correct side too. And make sure you have the correct bolt matching the oil hole in the head.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 03-06-2007, 05:19 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is gaining momentum as a positive member of FTE.
And there is the part about 45º from tdc to reduce stress on the shaft if I recall (welcome any correction here)
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #5 (permalink)
Old 03-06-2007, 06:25 PM
ranch67 is starting off with a positive reputation.
and make sure the shouldered bolt on rocker stand goes in the correct hole on reassembly.
thats an oil hole, no oil, you're screwed.
be sure to install dist. before tightening down the intake on assembly. you dont want to do it twice. and seems to me, shorter intake bolts go to the rear.
the 45 degs. is correct too!
be sure to use enough silicone sealant at end seals as well.
good luck
  #6 (permalink)
Old 03-06-2007, 06:54 PM
krewat's Avatar
Good point about the distributor being in the hole before tightening...
__________________
  #7 (permalink)
Old 03-06-2007, 07:51 PM
dffay is starting off with a positive reputation.
Check out the article about bent pushrods on the FE block. Its available in the Articles section: FE blocks that bend pushrods; a dirty secret.---something like that.
  #8 (permalink)
Old 03-07-2007, 10:46 PM
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
At over 37 years and over a million FE miles hotrodding never had "bent pushrods". Is this something I should know about? I'll do the same builds as before, they seem to work without oiling (flooding) and "bent pushrod" problems tjhank you.
__________________
.....=o&o>.....
  #9 (permalink)
Old 03-08-2007, 09:44 AM
I didn't find the article on the bent pushrods, but I'm using my original 1961 pushrods and adjustable rockers on the 3rd Fe motor, they must have a few hundred thousand, hard miles on them and I have never bent one?
__________________
JIM
1960 F100 Panel
223 3 spd overdrive
1966 F250
390 4 spd
  #10 (permalink)
Old 03-08-2007, 10:37 AM
390cobrajet is starting off with a positive reputation.
what is everyones opinion on replacing the cork gaskets with a bead of silicone? you know, run a bead and let it get somewhat stiff and then run a little more on top to make it tacky and then install manifold.
  #11 (permalink)
Old 03-08-2007, 10:56 AM
i've never used cork end gaskets. they move around when you position manifold.
also, there's a chance it will make manifold too high for bolt alignment.
run the bead, let it tack up and a little more works then position and lower.
  #12 (permalink)
Old 03-08-2007, 12:59 PM
RTV Silicone belongs in the bathroom, use Permatex's The Right Stuff on the end rails plus a light smear around the water ports. Center the dizzy bore.
I find a small dab of The Right Stuff at the head/intake joint, use a 100% rubber VC gaskets like Fel-Pro's VS 13049 R, contact to the VC's then add a thin coating of Permatex's 1 MotoSeal (item # 29132).
You'll have a dry motor without weeps or leaks. JMO's that work with me.
__________________
.....=o&o>.....
  #13 (permalink)
Old 03-08-2007, 04:20 PM
http://www.ford-trucks.com/article/i...le_Secret.html
  #14 (permalink)
Old 03-08-2007, 04:42 PM
Redmanbob's Avatar
Thanks I have been pending looking into the preload since the rebuild. Read this and realized the 352 was different, then lost the thread..
__________________
66 F100 352 V8
  #15 (permalink)
Old 03-08-2007, 04:43 PM
Quote:
Originally Posted by dffay
Thats a good article and info for the new to FE people, I guess its just standard procedure to unload and load the rockers for us who work on them more often, and forget to mention it in our helping
__________________
JIM
1960 F100 Panel
223 3 spd overdrive
1966 F250
390 4 spd
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
