Anyone Know of a Mfr of Carb Intake for 4.0??
another one was 4L block and crank, 3L rods and 5.0L pistons. Keeps 4L and gets you forged pistons provided you block can handle a 4" bore. Stroker 5.0L to 347cid run 3.4" stroke and 5.4" rods, the 4.0L has a 3.32" stroke and the 3.0L rods are 5.5315" so the rod ratio is decentat 1.67":1" where optimum is 1.7":1". Stock 4.0L is 1.73":1". The previously mentioned set up would be 2.07":1" which would be one hell of a screamer.
since weve completely derailed this thread I figure we might as well keep it going lol.
I did some more digging:
5.0L pistons use a 0.912" wrist pin. Guess what, the 3.0L also uses a 0.912" wrist pin. The 4.0L rod journal diameters are 2.1256". The 3.0L NON-Duratec rod journals are 2.1257".
That means the 3.0L rod will go right onto a 4.0L crank and the 5.0L piston will go right ontop of the 3.0L rod. I dont know how to find rod widths and what acceptable clearances are on them.
Originally Posted by RacinNdrummin
I think .050 would be pushing it on a 4.0, it would be worth a try though.
Originally Posted by rusty70f100
I talked to the machinist again today. Sonic testing complete. The walls vary from .170" to .240". That's with an existing bore of about 3.973". It would appear these are not the thin walled blocks I expected, or I got real lucky and got a good one. If so inclined, I dont see where someone couldn't take one out to 4", or beyond.
#28
Man.. this thread has really taken the scenic route thru hill and dale of 4.0 tech talk. I asked a basic ?? back a month ago and it's still going! It's a little off track but HEY! This is what these forums are supposed to do, I guess. So, the old ??, Does anyone make a 4.0 carb intake?? and a new ??. If I replace my 4X4 AT with a 2X4 tranny, will the on board ECM recognize everything OK or will it be confused? Are there fixes for any glitches that may come up? 94 4.0 EB Explorer
