1978 - 1996 Big Bronco
Rebuilding 302 for 88 Bronco, what are 3 good improvements
Old 08-26-2002, 05:32 PM
osceola's Avatar
osceola
osceola is offline
Post Rebuilding 302 for 88 Bronco, what are 3 good improvements
I'm having my engine rebuilt and would like to know what the best simple changes I can make while the engine is out. My only concern besides big money is, how these changes will effect the on board computer. I'm also concidering an exhaust system, stock manafolds w/single in 2 1/4 pipe,single out w/flowmaster 70's. The engine is currently fule injected (stock) w/efI dura spark >>>> I just reached the hight of my mechanical accumen. That why I come here for help! All Advice On This is Welcome Thanks, Mike.
Old 08-28-2002, 01:11 PM
cajunbronco's Avatar
cajunbronco
cajunbronco is offline
Cam,heads,exhaust.Cam selection for speed density EFI is critical.Call comp cams tech line they can give you some advice.You can have your heads ported and polished or buy aftermarket heads depending on your budget.The gt-40p heads found on the late model explorers flow better than the stock heads and are not that expensive.They will not work with the air injecion/airpump.But alot of folks delete that anyway.depends on your emissions laws.Freeing up the exhaust will help too.Just don't get carried away or it will actually hurt the low end torque.
Billy
Old 08-28-2002, 03:35 PM
luv mt truck's Avatar
luv mt truck
luv mt truck is offline
matthewstrss
03-07-2014 05:47 AM
arcaidy
03-07-2011 08:24 PM
devildog_0431
Exhaust Systems
05-27-2006 01:55 PM
rickthefix
03-17-2004 07:40 AM
jommer
12-22-2003 04:58 PM
Quick Reply: Rebuilding 302 for 88 Bronco, what are 3 good improvements
