Go Back   Ford Truck Enthusiasts Forums > Other Fords > Nite, Nascar and Other Limited Edition Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-04-2007, 12:44 PM
ford150man ford150man is offline
ford150man is starting off with a positive reputation.
Talking 1992 F-150 Flareside tires
Hello i have a 1992 ford F-150 flareside with 15 inch rims. What is the biggest size tire i can put on this truck? Thank you
  #2 (permalink)
Old 03-04-2007, 08:14 PM
roostercrows's Avatar
roostercrows roostercrows is offline
roostercrows is starting off with a positive reputation.
hey i think you can put 32 x 11.5 on your truck thats what i have on mine
the steers rub very little on a max turn.
  #3 (permalink)
Old 03-04-2007, 08:47 PM
Talking flareside tire reply
is your truck a stock f 150 2 wheel drive? No lift kit?
  #4 (permalink)
Old 03-06-2007, 06:57 AM
no its stock 92 Bronco no lift, im sure that thier the same.
  #5 (permalink)
Old 03-24-2007, 10:07 PM
JohnT's Avatar
JohnT JohnT is offline
JohnT is gaining momentum as a positive member of FTE.
Smile
I think 31x10.50 is the biggest tire that will fit on a stock 2wd F150. The fronts will rub a little on tight turns, though. I used to have a 95 F150 2wd with 31x10.50 all-terrain tires. I have 255/60/15s on my 92 Flareside, and I like the way they look.
  #6 (permalink)
Old 03-26-2007, 06:09 AM
92F150Flare 92F150Flare is offline
92F150Flare is gaining momentum as a positive member of FTE.
I don't do any off-roading so I run a street tire that is very quiet....size is 255/70-15. My truck has been dropped about 2-3 inches by the PO.....front and back.......My front tires extend about an inch outside the fender well......and do occasionally rub if I go over a heavy dip too fast......mostly some RR tracks around here.... No problems with full turning of the wheels at all.
I guess it just depends on what you need......off-roading or not.
Good Luck
__________________
`92 F150 Flareside - IRIS MET/Gray
5.0, AOD, 355 gears, dual glasspacks no cats, K&N drop in filter, MSD Blaster Coil, Cap and Rotor, Ford Racing 9mm wires - Blue
It's not pink......it's IRIS.
Have a look at my truck
Come visit the South Carolina chapter here!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
