Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #166 (permalink)
Old 04-21-2007, 09:56 PM
Ford-150 is starting off with a positive reputation.
Quote:
Originally Posted by David85
Also is there really a point for the deeper box? It seems to me it just restricts rear visibility, its not like you could actually use up all that volume for wet dirt ir gravel anyway.
you'd be surprised what we have put in my dad's company trucks (newer F-150s) he likes the deeper box because it contains stuff better, people don't always listen to what the payload ratings are, i have seen F-150s with more than 600# over their rating, the truck lowers in the back but it gets the job done and the truck still work for another 150k mikes, also the trucks would look very weird if they had a more shallow box, the rear visibility is fine in them, that's just my opinion
Sponsored Links
To remove this ad, register today!
  #167 (permalink)
Old 04-21-2007, 11:01 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Fair enough, all of our trucks (including my dad's gmc) have been well over their GVW rating at one time or another, I probably don't want to know what my two fords have been through in a previous life lol.
I guess it soes sortof make sense though, not many people buy f150s with 8f boxes anymore, so the exta volume could come in handy. I mention the visibility thing because I have heard of others complain about it.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #168 (permalink)
Old 04-22-2007, 02:13 AM
its all good
  #169 (permalink)
Old 04-22-2007, 10:33 AM
BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.
If I could ask for one thing it would be-
-Manual tranny with all engines.
If I could ask for many things-
-Manual tranny with all engines: That would cure most of the power problems and increase fuel economy
-Real Hubs: More reliable and increases fuel economy by disconnecting the axle shafts
-Electric cooling fans: Faster heat up/cool down, better AC at low speeds, increased fuel economy
-Go to some sort of direct valve actuation: Cut down on moving parts, increase fuel economy
-Go back to C channel frame: Lose the unneeded weight of the boxed frame, increase fuel economy
-Bedside lockable storage: Need I explain?
-Small diesel like the 4.4: Low end power, increased fuel economy. Power in the 300HP/450ft/lb range. Cross it over into the SD series as well.
-Interior light/dinger deactivation switch and cargo light turn on switch.
On a totally different note-3-4 cyl diesel for Ranger.
Mike
__________________
2000 F150 5.4 4R70W 4x4 Supercab 3.55 gears
  #170 (permalink)
Old 04-22-2007, 01:02 PM
David85's Avatar
We have one of those too. Ford offered a 2.2NA and a 2.3TD lateron in the mid 80s for the ranger. Ours has the later 2.3 mitsubishi turbo. It won't do a burnout, but you can keep up with traffic and get great fuel economy while doing it. It will likely outlive the truck (it already outlived the donor vehicle).
Ford went with a boxes frame for the better torsional stiffnes (the cab and box don't move in opposite directions when cornering) and they got good reviews for it. But it does come at a price, and I can tell you that a LWB 86 truck will corner just fine even with its very flexible frame.
You may think I'm crazy for saying this, but I think the cummins 3.9L diesel could be a good fit. Its only 170hp but with over 300ft/lbs of low end torque, 22+ real world mpg should be possible. Ford is working on a diesel option for the f150, but we'll have to see how it turns out. The new 6.4L for the superduty, was a disappointment in terms of fuel economy, and will be replaced after only a few years.
__________________
  #171 (permalink)
Old 04-22-2007, 06:04 PM
B's FX4's Avatar
B's FX4 is starting off with a positive reputation.
ya know, its to bad they are going to ax the ranger, a diesel in that little guy would be a great idea, i mean a lil truck to do work with and good mpg to commute....ok lets build it....in theory id buy one.....
  #172 (permalink)
Old 04-22-2007, 07:00 PM
ec_fritz is starting off with a positive reputation.
Quote:
There's a lot of wasted potential in every aspect of the ranger.
  #173 (permalink)
Old 04-22-2007, 07:38 PM
fonefiddy is starting off with a positive reputation.
That's true. They used to make a Ranger Scab w/ long box. I wish I could find one. I'd buy it tomarrow.
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
  #174 (permalink)
Old 04-22-2007, 09:22 PM
David85's Avatar
Ford offers a really nice mid size truck in australia (Its called a ranger, but looks better), not one, but TWO different turbo diesels to choose from (2.5l and 3.0l), and guess what - they come with a crewcab. 6600lbs of towing and an avalable close ratio 5 speed manual transmission, it is also capable of close to 30mpg. Yeah, I'd consider buying one of those..........
__________________
  #175 (permalink)
Old 04-22-2007, 09:46 PM
B's FX4's Avatar
no kidding? seems like all of fords better ideas are in austarila or europe and not here where we need them....im going to see if i can find specs on those 2 diesels just for the heck of it....
  #176 (permalink)
Old 04-22-2007, 10:20 PM
David85's Avatar
If memory serves, the stock numbers are comparable to a N/A 6.9l diesel. It seems to be a very nice truck, you should check out the ford falcon ute while you're at it.
__________________
  #177 (permalink)
Old 04-23-2007, 12:53 AM
Quote:
Originally Posted by Simmy150
Tell us what features/upgrades you'd like to see in the new F-150.
Something similar to this
Added on edit:
3.0L 16 valve intercooled Direct Injection Turbo-diesel
115kW of power at 3,200rpm
380Nm of torque at 1,800rpm
fuel economy at 9.2L/100km ~
  #178 (permalink)
Old 04-23-2007, 12:57 AM
David85's Avatar
Yep, thats the one. I've never bought a new vehicle in my life, but if ford offered that unit around here (5 min. after hell freezes over) I would buy one.
__________________
  #179 (permalink)
Old 04-23-2007, 01:00 AM
I'd be right behind you at the dealer.
  #180 (permalink)
Old 04-23-2007, 01:10 AM
David85's Avatar
........But I might find myself distracted by one of these bad boys....
http://www.fpv.com.au/cars/f6-tornad.../overview.aspx
Another version of it is avalable with a 5.4l that puts out nearly 400hp and about the same for torque. Why can't the f150s around here do that?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
