removing door panels 2003 f-150 - Ford Truck Enthusiasts Forums
Old 10-18-2002, 03:02 PM
American Muscle American Muscle is offline
American Muscle is starting off with a positive reputation.
Old 12-05-2002, 05:28 PM
smoothcharacter smoothcharacter is offline
smoothcharacter is starting off with a positive reputation.
Post removing door panels 2003 f-150
If anyone could help me before I damage the door, I am
wanting to replace my factory stereo speakers in my new 2003 F-150
but I do not see any screws on the door panel. I had a '96
ranger and installed the stereo myself but I do not
want to damage the door panels in my new truck.
Thanks
Old 12-05-2002, 07:18 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
1. Disconnect negative battery ground cable.
2. Remove sail panel. This is the little triangle located at the top front area of the door panel (hiding outside rear view mirror mount)First pull the triangle towards you until plastic mounting stud is released from door, then tip the whole assembly forward to free the tab located at the lower left corner of the triangle.
3. You will now see a screw holding the door panel in place in that area. Remove it.
4. Remove the power window switch assembly by pulling it up with your bare hands. Unplug wiring harnesses.
5. Look inside the cavity. You should see another screw. Remove it.
6. With a thin flat-bladed screwdriver and a light touch, remove the door light lens. I believe a small slot exists on the lens for this purpose.
7. Remove now-visible screw.
8. With same flat-bladed screwdriver, pry loose the oval trim around the base of the interior door handle.
9. Remove handle by unscrewing now-visible bolt.
10. Bearing in mind that the door light and power mirror harness are still attached to the door panel, remove panel by LIFTING UPWARDS.
11. Unplug door light socket by turning a quarter turn and pull out.
12. Unplug power mirror harness.
Reverse for installation. Use a light touch when sliding door panel down onto door during assembly. It is easy to crack the "L" shaped plastic connecting hooks.
Old 12-05-2002, 08:29 PM
REVISED STEP 2 (Difference in CAPS)
view mirror mount)First pull the UPPER TIP OF THE triangle towards you until plastic mounting stud is released from door, then tip the
Old 12-05-2002, 08:35 PM
well my ex cab f-150 2003 has solid panel door.
no triangle hiding the side view mirror and
the light cover has no screw underneath.
no visable screws anywhere.
still complexed.
Old 12-05-2002, 09:39 PM
OK. My bad. I thought the removal procedure for an F-150 door panel was the same as my Expedition. To make amends:
www.ford-trucks.com/articles/speaker_inst.php
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 08:56 PM
Tags
1997, 2000, 2003, 98, door, f150, ford, inside, lens, panel, panels, remove, removing, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
