Firing order on a 360 - Ford Truck Enthusiasts Forums
Old 03-03-2007, 07:58 PM
FORDguy360 FORDguy360 is offline
FORDguy360 is starting off with a positive reputation.
Before I start my truck up, I want to make sure the plug wires are on correctly. I found this diagram on the internet and I want to make sure this is right. When I replaced the spark plugs, I took two wires off at the same time and then I forgot which one went where.
Thanks,
Jake
Old 03-03-2007, 08:16 PM
LOWBOY1979's Avatar
LOWBOY1979 LOWBOY1979 is offline
LOWBOY1979 is starting off with a positive reputation.
Looks good to me I don't have my book in front of me, but it looks right. If its not you will know in a hurry. if you start it and it dosn't sound right you know which two are swapped. I will not hurt anything if you start it. Good luck Jesse.
Old 03-03-2007, 10:43 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Yes that's correct. where did you get that illustration as I have been looking for something as good as that ?
Old 03-03-2007, 11:43 PM
Quote:
http://www.autozone.com/servlet/UiBr...3d800a504a.jsp
Thanks guys. I will check it out tomorrow to make sure I have them on correctly.
Old 03-04-2007, 01:20 AM
Thanks, I have linked to that set of pages tons of times but never looked at the firing orders
Old 03-04-2007, 02:02 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Looks like it's straight out of a Chiltons manual. Very clear and easy to read.
Old 03-05-2007, 05:19 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Quote:
Yeah but. :)
What's with the "back arrow" pointing the wrong way?
Alvin in AZ
Old 03-05-2007, 05:34 PM
The arrow is correct, counter-clockwise roatation.
http://boxwrench.net/specs/ford_352-428.htm
Old 03-05-2007, 05:47 PM
[QUOTE=Mil1ion]The arrow is correct, counter-clockwise roatation.
http://boxwrench.net/specs/ford_352-428.htm[/QUOTE]
+1
Plug Wires frwgt350net 1967 - 1972 F-100 & Larger F-Series Trucks 36 06-03-2016 11:01 AM
1975 F250 360 choke wiring Colorado Highboy 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-03-2016 04:23 AM
Wiring mess alternator/solenoid/ignition stryke23x 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-28-2014 07:40 AM
1970 F250 360 PCV / brake booster ??? DanoF250 1967 - 1972 F-100 & Larger F-Series Trucks 7 12-30-2010 03:44 AM
360 , 390 spec's alfuson FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 06-04-2009 12:10 AM
Tags
1973, 360, 360ci, 360firing, 75, diagrams, engine, f250, fireing, firing, ford, ignition, order, sequence, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
