help getting wheels off
cant get the front wheels off late model lightning. ive done everything i can think of to get the front wheels off pried kicked rubber mallot sprayed with penetrant let sit even loosened the lugs an put it on the ground and turned the wheels side to side .about the only thing i havnt tried is putting the lugs on and driving in circles ive seen what happens when they break loose that way not a pretty sight for the wheel any good ideas the wheels have never been off the vehicle before . and yes even shouted obsentities
we normally just get them jacked up safe leave one lug on then take a 8 pounder and let loose from under at the tire.
when you do get it off clean all the gum and gunk off the hub and apply never seize around the hub before puting it back on to help you out the next time.
best if you do all 4 at the same time as we always find more then one frozen on at the same time.
93XLT150
16
02-19-2011 08:47 PM
crash1068
1997-2006 Expedition & Navigator
01-08-2004 05:34 AM
