Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2007, 12:46 AM
ganluin is starting off with a positive reputation.
Wierd starter problem
Hi all!
I have a 90 2wd 3.ol Aerostar. I recently(aprox 1 month) replaced the starter. The same day after running my van all day with no problems, I stopped to do some banking and when I came out of the bank I could not start the van. All that happened was I heard a clunk and then the lights went out, literally. There was no power. after about 10 mins I noticed the overhead lights had come back on. I tried to start it and got the same results so I figured I was poping a circuit breaker some where. Anyway after the power came back I tried a third time and the van started fine. That was a month ago.
Today, after running fine all day, I stop at the house and when I go back out and try to start it, I hear a clunk, and the power goes away. This time have waited for the power to come back and tried to start it several times with no luck.
Looking for some suggestions to get me rolling in the (right/some) direction on this.
Thanks for the help,
Gene
p.s. I have searched the forum and found lots of starter posts but nothing similar.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-02-2007, 01:31 AM
copper_90680's Avatar
copper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to behold
Hi Ganluin:
Welcome to our FTE forum
I'd start out by cleaning up the battery posts and tightening up the connections to the starter. Also check the ground cable going to the engine.
If it still does that, check the battery itself, and don't rule out the possibility that you bought a defective starter.
At this point, your battery looks like the prime suspect.
__________________
Tung
'93 3.0L Aerostar 2WD
'95 4.0L Aerostar AWD
'93 3.8L Taurus
Please check out our guideline
http://www.ford-trucks.com/guidelines.html
Wife? What wife? Oh, The Supreme Commander!
  #3 (permalink)
Old 03-02-2007, 02:12 AM
Aeroman59's Avatar
Aeroman59 is starting off with a positive reputation.
Bad battery?
I'd second above. When fully charged you should see about 12.8 volts from the battery (no load). You can check for a bad cell with a hydrometer, (unless you have a maintenance free battery) test each cell individually & they should all be about the same & give a fully charged reading (cant remember the exact S.G. reading). If one is substantially lower you have a bad cell & this could be the cause. Your cranking voltage will be lower & this will give problems.
It's also highly possible you have a loose/ dirty connection somewhere, this you can usually track down with a voltmeter. Anywhere there is a junction or terminal of a wire is an area for "voltage drop" caused by corrosion or a loose connection.
  #4 (permalink)
Old 03-02-2007, 05:59 AM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
many auto parts stores will load test the battery and do a test of the starting/charging system for free....
Autozone is one...call ahead to confirm
just say no to their parts sales pitch and shop around...
can always beat Autozone prices at your local discount auto parts stores
glad you stopped by ganluin
keep on Aeroing
  #5 (permalink)
Old 03-02-2007, 12:28 PM
Aeroman59's Avatar
Clunk or click
Also you could have a mechanical problem, starter motor has an inertia gear on it, which engages the flywheel to turn the engine. When the starter spins ,this gear moves axially along the starter motor drive shaft, it can jam if there is sufficient wear on either flywheel gear ring or starter gear. Usually on a manual transmission you can rock the car in gear & the gear will fly back to the disengaged condition. I dont know if this technique would work with Auto transmission. The click/clunk? you are hearing could be the starter gear jamming. A heavy "click" is just the starter relay engament & is normal, but you dont notice it if the starter spins normally , due to background noise of the starter motor.
regards Aeroman.
  #6 (permalink)
Old 03-02-2007, 01:20 PM
lv2race is starting off with a positive reputation.
You can remove the torque converter access plate, 2 small bolts, and check for broken flywheel gears. But that doesn't explain the power loss.
__________________
J Lowe
'90 F-150, 4.9
'00 Expo, Triton 5.4
  #7 (permalink)
Old 03-02-2007, 03:17 PM
aero92 is starting off with a positive reputation.
I believe the lack of power comes from a corroded terminal that when Load is placed on the battery is not making good contact. A defective relay would not diminish your accesories as they are powered separate from the Starter.
In order to replace the starter you removed the (-) cable. Right? If it had a white powder that's probably gonna be your issue. Take out the battery and clean the posts. I replaced my terminals with ones from Autozone that have a little lever as quick disconnect.
  #8 (permalink)
Old 03-02-2007, 06:17 PM
Hi all! Thanks for all the replys! I just got back and am going out to work on my van right now. Will try the suggestions and let you know what comes up.
Feels good to know I have some were to go to get quick answers. This vehicle is my primary work vehicle for my business. I am the sole operator, chief worker and every hat wearer fo my business and when my van goes down everything comes to a halt until I get it back up and running.
Again, thanks and I will let you know what happens,
Gene
  #9 (permalink)
Old 03-02-2007, 08:53 PM
99f350sd is starting off with a positive reputation.
Battery connection 100%
Dick
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..Diablo Predator
MDII Plow, 200 amp alt timbrens,Revo's
85f150, Two 96 aero*awd 4.0 ext. 05 mountaineer V8 Awd
Lever's are cool enough for me too...LOL
  #10 (permalink)
Old 03-03-2007, 03:53 AM
Ok, ok, ok! I bow down to the Aerostar gods who came before me! hehe.
Even though I was highly skepticle and every part of me was saying crawl under the van and pull the starter and be done with it, I cleaned the battery posts and connectors. Charged the battery for a few minutes and then started my Aerostar!
She started right up! Thanks all!
Gene
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
